40 micron filter before pump?
Discussion in 'The Hokey Ass Message Board' started by friggin"A", Jun 10, 2010.
  1. friggin"A"
    friggin"A"
    I've been reading that you should have a 100 micron filter before your electric fuel pump to avoid cavitation, but I found this out after I had already installed my 40 micron... I don't have a problem switching it out and doing the "correct" thing, but wanted to run it by you guys first since 100 micron filters are not cheap!
    I'm running a Summit pump (140gph, 14psi) and their regulator which will dial things down to 4.5-7 psi since I'm running a carbureted 5.0. Let me know what you think.
  2. friggin"A"
    friggin"A"
    bump
    guess this isn't the most interesting topic, but would appreciate some thoughts
  3. bobscogin
    bobscogin
    I'd leave the 40 micron filter in the system and try it out. As long as it doesn't restrict the fuel, that's good enough.
    Bob
  4. dirt t
    dirt t
    1. HAMB Old Farts' Club
    Street Rodder or Rod & Custom just had an artical on that.
