guys, i need a few dimensions on a 40 style banjo rear.. im working on milling some parts for my own open drive kit. ill post pics once its done. problem is i dont have a rear out of a car in front of me. so what i need: i need the distance from the face where the torque tube bolts on, to the hole that goes throught the pinion shaft for the coupler. also i need the bolt pattern of the torque tube flange. i know its a 6 bolt pattern, but i need to know the cross measurment from center to center of the bolts. with this info, i can make my entire setup fairly easily any help would be appreciated! thanks
Ok I got the bolt circle and drew up that flange. I still need the pinion coupler hole from this face in the rear end Posted using the Full Custom H.A.M.B. App!
Would you happen to have a drawing of the center section housing? Posted using the Full Custom H.A.M.B. App!
as of right now all i have is the torque tube mounting flange. eventually ill have the entire enter when i have one in front of me to lay out.
