40 vs 47 Ford Truck cab
Discussion in 'The Hokey Ass Message Board' started by GreenMonster48, Oct 1, 2008.
  1. There's a '40 Ford pickup cab listed for sale locally. I realize this has probably been posted before, but are there any quick visual que's that distinguish the two? It's only the cab and doors.
    Thanks.
  2. PurplePearl50
    PurplePearl50
    from Sedalia,Mo
    From what I was told on mine. The only way to tell is where the front fenders mount to the cab. 40 had a strip that they bolted to and 45-47 didnt.
    I hope this is right
    Dane
  3. Primered Forever
    Primered Forever
    from Joplin,MO
    I believe the 40-41 had the tank under the bed and the 42-47 had the tank under the seat so there will be a hole in passenger side of cab on the 42-47 for the filler neck.
  4. hotrodder3
    hotrodder3
    from maine
    i used a 47 pickup cab to build my 40--i couldnt find any differences between the two except door glass has a steel reinfocement around it--doors as far as i can see are identical--i could be wrong but it worked for me--i built my truck cheap---i put over 15000 miles on it since april & am enjoying the hell outta it (Im Retired)
  5. If that's the case then I guess this one is a '40! May have to go look at it tonight. I've already got a full set of fenders and a hood from my great grandfather's 41.
    Thanks everyone.
  6. oldrelics
    oldrelics
    from Calgary
    Besides the floor pan differences between '40-'47 (under seat well, seat riser, m/cyl access hole), there are differences in the cabs between '40-'41. The '40 has a slightly raised panel in the center of the dash panel where the 'Ford' script goes. A '41 is flat in that spot and used a Ford script plate in that spot. Also in the '40-'41 there is a difference of firewall stamping where the voltage reg goes-different placement of the beads. Now we are talking 1/2 ton cabs. The bigger truck cabs are different as well.
  7. 40Standard
    40Standard
    from Indy
    for just a quick look, gas filler on passenger side is a 42 up
  8. rdscotty
    rdscotty
    from red deer
    "The bigger truck cabs are different as well."
    What are those differences? Does it prevent them from being used on a 1/2 ton build?
  9. All my 41 big trucks have the gas filler in the cab.
