Projects 40 Willys Project
Discussion in 'Traditional Hot Rods' started by ALLSTEELWILLYS, Jan 15, 2011.
  1. ALLSTEELWILLYS
    ALLSTEELWILLYS
    from TEXAS
    It was popping pretty bad today. And backfire through the ram tubes. Also didn't Rev very smooth, kinda rough. Any ideas? I'm thinking it's timing, but I could be wrong!
  2. loudbang
    Backfire up could be timing or too lean.
    ALLSTEELWILLYS likes this.
  3. ALLSTEELWILLYS
    ALLSTEELWILLYS
    from TEXAS
    Thanks, I'm still trying to tune it! Is The Day of The Drags in Temple, just a drag race? Or is it a show also? Thinking of hauling the Willys up there, IF I can get it running better.
  4. elgringo71
    elgringo71
  5. jay t.
    jay t.
    Thats it ,I'm pulling my 40 coupe out of the corner of the garage to start working on it. Awesome car you have. I first saw a youtube video of your car and then found this thread. Thanks for the inspiration
    ALLSTEELWILLYS and elgringo71 like this.
  6. elgringo71
    elgringo71
    Here is a picture for inspiration. Don't leave us hanging on this thread, inquiring minds want to know.
  7. ALLSTEELWILLYS
    ALLSTEELWILLYS
    from TEXAS
    Thanks Man! I need it. Still thinking of leaving it as is for awhile. So I can get it running prefect, than tear her down for paint.
    Still struggling with the injection, getting it right. Seems like one side is richer than the other!
    elgringo71 likes this.
  8. glrbird
    glrbird
  9. ALLSTEELWILLYS
    ALLSTEELWILLYS
    from TEXAS
  10. ALLSTEELWILLYS
    ALLSTEELWILLYS
    from TEXAS
    Any Hydromatic guys following this thread?
    My dad had a manual pull cable mounted on the dash that ran to the transmission. I'm guessing this is normally attached to the carb, like A TV cable?
    I'm going to replace it, basically just a newer version of what he had, is there a certain setup procedure for this?
    Phillips and 37willysgasser like this.
  11. elgringo71
    elgringo71
    Here is a Willys Coupe from the San Antonio area that your dad might remember
    loudbang and 41 coupe like this.
  12. 37willysgasser
    37willysgasser
    My truck has a B&M hydro in it, it has a lever cable to pull it into race mode, that goes to the trans, what kind of hydro do you have?
    CGkidd and loudbang like this.
  13. CGkidd
    CGkidd
    I have a scanned B&M book the shows the cable hook up. I will see if I can get it scanned.
    Sent from my SM-G900V using The H.A.M.B. mobile app
  14. ALLSTEELWILLYS
    ALLSTEELWILLYS
    from TEXAS
    Thank you! Got my new cable in the mail today!
  15. mutant55
    mutant55
    CGkidd, I could use a copy of that page in the B&M book too, I would like to know how to hook up a cable on my Hydro Stick too.
    ALLSTEELWILLYS, can you post pictures of how you set yours up when you install it?
  16. CGkidd
    CGkidd
    Haven't forgotten just been super busy. I will try tonight
  17. ALLSTEELWILLYS
    ALLSTEELWILLYS
    from TEXAS
    OK no problem.
    Mutant55-yes I will when I get it setup and working
  18. mutant55
    mutant55
    Thanks, this is one of the make or break set ups for running a Hydro from what I know. It's either throttle linkage, or I have heard of the cable set up, but personally have not seen one operational, so this has my interest peaked for sure.
  19. ALLSTEELWILLYS
    ALLSTEELWILLYS
    from TEXAS
    I still can't decide if I want to mount the handle of the cable to the floor pan by my shifter, or on the dash like it was.
  20. ALLSTEELWILLYS
    ALLSTEELWILLYS
    from TEXAS
    Cable linkage at transmission. Guessing this is a aftermarket piece, comparing it to the stock linkage on my spare transmission.
    CGkidd likes this.
  21. mutant55
    mutant55
    So a cable just like a choke cable hooks to this arm, and you just pull it wide open before you start driving? Or how are you applying how much cable you are pulling in?
  22. ALLSTEELWILLYS
    ALLSTEELWILLYS
    from TEXAS
    Yes basically. My dad pulled it all the way, for drag racing. So the trans thinks you are at wide open throttle.
  23. mutant55
    mutant55
    Has anybody on this thread done any street driving with a set up like this?
  24. ALLSTEELWILLYS
    ALLSTEELWILLYS
    from TEXAS
    I got the new master and wheel cylinders installed and bleed. Now to drive it and see if stops any better.
    Now making a bracket to attach the trans cable, the original wasn't very nice looking.
    elgringo71 and loudbang like this.
  25. CGkidd
    CGkidd
    I can't find the file with the info but will keep looking.
  26. mutant55
    mutant55
    Ok CG, let us know when you do find it, I am really interested in seeing what you have.
  27. ALLSTEELWILLYS
    ALLSTEELWILLYS
    from TEXAS
    No problem. Almost got my bracket finished. Hoping to get it setup this weekend
  28. ALLSTEELWILLYS
    ALLSTEELWILLYS
    from TEXAS
    Happy New Year!
    Fired up the car today! BUT once it warned up it died. Like it ran out of fuel. The last time I ran it, it did the same thing. It won't restart either, it will run off fuel when I shoot it down the manifold though. Any ideas?
  29. loudbang
    Gas cap vented? Try leaving the gas cap off next time and see if that works.
  30. ALLSTEELWILLYS
    ALLSTEELWILLYS
    from TEXAS
    The fuel tank is vented. I have a 6an vent hose. But I'll try leaving the cap open next time
