Technical 41-48 ford cross member
Discussion in 'Traditional Customs' started by topher5150, Jun 22, 2024.
  1. topher5150
    topher5150
    So original plan was to use the lowered cross member but that didn't work out so I put the original back on and this was already a few years back. Fast forward a few years and everything looks a little off. Kind of hard to see in the pic but the shock rubs against the mount and the axle doesn't quite line up with the bumpers.
    Can someone confirm
  2. redo32
    redo32
    You should have spacers on either side of the shock to center it in the bracket and then tighten the bolt.
    alanp561 likes this.
  3. topher5150
    topher5150
    I get that, but the way the shock sits I had to force it into place so now it sits at an angle
  4. 19Fordy
    19Fordy
    Can you drill new mounting holes in the shock bracket and move it rearward so
    the shock is straight and centered in the shock bracket without the side pressure you are now
    encountering?
  5. topher5150
    topher5150
    I could definitely do that. I'm just concerned about it messing up the alignment for anything else.
  6. redo32
    redo32
    So you're thinking the entire axle has shifted back? Check the wishbone ball and socket and the rubber cushion.
    '28phonebooth and alanp561 like this.
  7. topher5150
    topher5150
    My wishbone is split
  8. gary macdonald
    gary macdonald
    Did you split the wishbone? If not then there not much of a way the axle could move back without bending the split bones or breaking it’s mount.
