Technical 41-48 ford front crossmember
Discussion in 'The Hokey Ass Message Board' started by 1980gold, Aug 21, 2015.
  1. 1980gold
    1980gold
    has anyone ever used this crossmember from speedway to lower the front end of a 41-48 coupe. mine has a sticj front suspension, small block chevy w automatic. I am just curious how it would work out thanks
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    I am pretty sure that is the route I am going to go on my 46. It is pretty straightforward, the stock crossmember has a severe drop and by flattening that out you can lower the car 3 inches, without going to a dropped axle and all the modifications that go with that.
    The one drawback is that a flathead won't work with it, but you and I are not running one of those. Hope someone chimes in who has used it.
    Don
    If you look at how deep the stock crossmember is, the Speedway flatter crossmember has to drop it down quite a bit.
  3. 1941coupe
    1941coupe
    I used one on a 47 ford and worked great,a bonus is you can use stock fuel pump if I remember correctly
  4. 1980gold
    1980gold
    do you think split bones would make a difference?
  5. Don's Hot Rods
    Don's Hot Rods
    from florida
    41coupe, tell us more. Did it create any angle issues with the wishbone ? Any other suspension/steering clearance issues ? I am going to split my bones and run an automatic, is that what you did ?
    Glad to hear you liked it.
    Don
  6. 1941coupe
    1941coupe
    I split my wishbone w/ ch***is engineering kit 350/350 9" 68 bronco rear.used a 605 gm power box and pitmen arm stock 47 cross steering,block hugger exhaust, worked well no issues
  7. Don's Hot Rods
    Don's Hot Rods
    from florida
    Thanks for that info, it really helps. What does that steering box come out of, sounds interesting. I was planning on running the stock steering box, but that sounds better.
    Don
  8. sdroadster
    sdroadster
    I bought one of those cross members for my untouched 48 four door, and ended up throwing it out. Almost none of the bolt holes lined up. I called Speedway, and it seemed as though they could have cared less. I ended up using the stock cross member, and cut the top out of it. I then fabricated some 3/16 metal for the top and sides. I have a Oakie Joe dropped axle, a Posie reversed eye spring, and the modified cross member. The car is pretty low, but I like it that way. With the modified stock cross member you have the advantage of adding a shim plate between the spring and cross member if you choose to adjust the ride height. My car has he stock steering box, and stock steering wheel. I drive the car everywhere. I used Ch***is Engineering motor mounts, trans mount, and parallel rear end kit. I used a junkyard Ford pickup rear end with a 3.00 ratio. Save the money and modify your cross member.
  9. Don's Hot Rods
    Don's Hot Rods
    from florida
    I think I saw a review where someone else said the bolt holes didn't match up, but I will be welding mine in, if I go that route.
    Good info though.
    Don
  10. 1941coupe
    1941coupe
    I forget what car the box came out of but any mid size gm 605 box late 70s not the larger 825 unit,get the adaptor that completely replaces the stock steering box mount as it gives more exhaust clearance, nothing wrong with stock box will work just use narrow tires like 205/75/15 series or smaller for eazy steering
  11. Tim
    Tim
    from KCMO
    Kind of a long shot but any photos of the stock cross member and the speedway one next to each other?
    I also used the ch***is eng inc motor mounts and etc and I can't fathom any less dip in the front cross member. I could hardly get my front spring U bolts in the cross member with the engine in
  12. 1980gold
    1980gold
    thanks for the replies I got my reverse eye spring today in the mail 1941 coupe I believe I have the same the same wishbone kit w the bones mounted under the trans w tie rod ends. If I do the reverse eye spring ( its a posies 5802040 2" drop) should I relocate the bones to the frame rails? I am afraid the ch***is is going to be too tight w the bones? any ideas Thanks
  13. 1980gold
    1980gold
    also if I do a dropped axle. I measured my kingpin centers before and they are close to 49" w the perch centers almost 39". I don't wanna order the wrong one, the widest I see to order is 48" w roughly what I have for perch centers
  14. RICH B
    RICH B
    I bought a similar one from the Forty Fort and put it (welded) in my '47, then I added a Posies spring, then I "C" notched the frame for spring & axle clearance, then the wishbones hit on the frame so I dropped them at the yoke, then relocated the drag link to the bottom of the steering arm, also made a new panhard bar to fit along with adapting a Weedetr anti-roll bar. Haven't got the car on the road; but it looks like it should work. If I ever did it again would probably use a dropped axle & low spring with the stock crossmember.
  15. fordor41
    fordor41
    remember 41's frames, at least in the front, are not the same as 46-48. more like a 40
  16. 1980gold
    1980gold
    Does 40 have the spring in front of the axle?
  17. rusty rocket
    rusty rocket
    I did one years ago. It wasnt from speedway. I used a poisies reversed eye spring and stock axle but it wasnt low enuff for my liking. I found an old 2 inch dropped axle and that made it sit nice.
  18. craig.maverick
    craig.maverick
    from Australia
    Pull all the old stuff, bolt in a series 3 jag front end complete with power rack. Drives & stops like a new car.
  19. 1980gold
    1980gold
    that sounds like a nice idea but for right now I'll have to stick w/ the axle or crossmember and the leaf
  20. Don's Hot Rods
    Don's Hot Rods
    from florida
    I'm like you, part of me knows that a MMII front end setup would ride and handle better, but I already have a 46 parts car with the complete suspension under it, so that will be what I will use. It will get power discs on the front and some tube shocks, but otherwise stock, but dropped, Ford stuff.
    I already have a parallel spring setup for the rear, and will use lowering blocks on that to get the right stance.
    Don
  21. 1980gold
    1980gold
    The ifs seems like it is a pretty big job and expensive too. I am gonna attempt to move my already split bones to the frame rails tomorrow when I'm off and go from there. My exhaust is running under them right now if you could imagine ( previous owner thought that was ok)
  22. Tim
    Tim
    from KCMO
    @1980gold @Don's Hot Rods @1941coupe
    Just bumping this to the top with a quick question. How much clearance do you have where the wishbones are p***ing under the frame? Also how much room until your on the bump stops?
    I'd love to go lower and keep my solid axle up front but I'm going to need more than an inch of suspension travel before stuff hits.
  23. Tjames
    Tjames
    On my 41 Tudor I used a 4 inch drop axle from Magnum and 2 inch drop spring from Posies
    Sent from my KYOCERA-C6742 using The H.A.M.B. mobile app
  24. 1980gold
    1980gold
    I ended up doing the magnum axle this past weekend. I didn't do the crossmember. I used the reverse eye spring also. I neglected to tell the supplier a that I had disc brakes so my steering arms didn't fit. I ordered a set from ch***is engineering. As far as clearance everything ( drag link and tie rod) stayed in the same spot. I may have to shorten the tie rod about an inch but I'll wait till the steering arms get here
