41-48 ford with sbf?
Discussion in 'The Hokey Ass Message Board' started by pie pie, Feb 1, 2009.
  1. pie pie
    pie pie
    from missouri
    does anyone have any picture of any 41-48 fords with a sbf or mabey build pitures without the front clip on? what steering issures did u run into?
  2. Itsa48Ford
    Itsa48Ford
    Pick-up or Car ?
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    You don't run into steering issues if you use a Bronco pan which moves the sump to the rear just like an SBC>
  4. Get the kit from Ch***is Engineering in Iowa. They have a bolt in kit and if you are using a C-4 ****** you don't even have to split the wishbone....
  5. 416Ford
    416Ford
    What are you looking for? Motor mounts? Pan clearance? Exhaust?
  6. hotroddon
    hotroddon
    People love to say that the elusive early Bronco pan is "Just like an SBC". Unfortunatley that's not quite true. The Ford oil pump is still in the front and makes for a deeper pan in the front than a Chevy. The early Bronco, which is quite rare does help as do many of the late model dual sumps., but none are as shallow as an SBC
    [​IMG]This is a genuine, rare early bronco pan
    [​IMG] Another picture of the early bronco Style
    [​IMG] This is one of the more common late model pans with a dual sump - newer Mustang, Crown Vic etc.
  7. pie pie
    pie pie
    from missouri
    its a coupe and m sticking with straight front axle, steering box is undecided yet. planing on 4 bar in front with it slammed and either a c4 or a manual ******. im putting in a 351.
  8. pie pie
    pie pie
    from missouri
    im also planning on a 4-bar setup in the front as well
  9. Dirtynails
    Dirtynails
    from garage
    No need for the four bar if you are using a SBF, even a cleveland is narrow enough to clear the steering column. The stock front end with a dropped axle and decent brakes actually works well.Especially if you clean up the sway bar with decent bushes etc .
  10. Weedburner 40
    Weedburner 40
    Stay away from a four bar on the front of any spring in front of the axle car. The bushings don't live. Stay with the wishbone, split or not. We make a kit for splitting the wishbone if needed. If using a 289/302, the late dual sump pan will work. If using a 351W, get the van pan and pickup tube, it is the shallowest pan for the Windsor. I have the part #'s for them if you need them. We also make several mounts for the SBF engines. Steering shouldn't be a problem either. Check out our website for other parts for your ride.
    www.weedetrstreetrod.com
  11. pie pie
    pie pie
    from missouri
    what about the adjustability of four bar compared to splitting the bones? im planning on a 525 box
  12. lakes modified
    lakes modified
    Like he said, you don't need to split the wishbone.The sbf will fit fine. I have been running one in my 48 merc coupe for over 30 yrs with the stick wishbone & a dropped axel. I use a 74 ford PS box, located in the stock location, but with some work to make it fit the way I wanted it, so it would all line up with the steering column.Keep in mind, you will need to install a dropped tubular cross member adjacent to & below the steering box.The frame flexes there so much when sitting still it's really bad.
  13. pie pie
    pie pie
    from missouri
    hows the ride? im trying to get a pretty decent ride and handling and i dont wanna go with ifs.
  14. trailer-Ed
    trailer-Ed
    from JC, MO
    Put in on a Ford Ranger ch***is. That would be so boss dude!
