41 chevy pickup
Discussion in 'The Hokey Ass Message Board' started by zorro-z, Mar 3, 2010.
  1. zorro-z
    zorro-z
    I would like to replace the original rear end with a newer, 6 lug pattern, 3:50ish or less ratio,but would like to use existing springs and just bolt another in and figure out new shock mounts afterward. I am told 55 chevy pu could work ? Any help is appreciated. I will have a 283ci and 350 turbo in front.
    zorro-z
  2. sdrodder
    sdrodder
    from Houston TX
    I dont exactly know the ratio of a truck rear end but my dad put in a 55 chevy truck rear end under his 36 chevy truck using the stock springs. All we did was get new pads which were welded to the axle.
  3. solid
    solid
    MY 2000 SILVERADO IS 6 LUG. HAS 3.42 POSI(LOCKING), and you can get them pretty reasonable. make a great hot rod rear for your truck if it's narrow enough. may have to re weld spring pads.
  4. pugs
    pugs
    from Hamburg Pa
    look at the k model blazers see a few of them at the yard with 3:42 rears
