Technical 41 coupe door adjustment
Discussion in 'Traditional Hot Rods' started by 1980gold, Oct 7, 2015.
  1. 1980gold
    1980gold
    On my 41 ford coupe my passenger side doors whole rear edge sticks out about 3/8" The front gaps don't seem bad but the rear is . It doesn't close easy like the d/s which is perfect. Any ideas?
      43.9 KB
  2. caton462
    caton462
    Looks like the door matches above the handle (bent door?). Maybe 2x4 just above the handle and push a little at the top and a lot at the lower rear corner.
  3. 1-SHOT
    1-SHOT
    from Denton
    Use a thick phone book it will not leave any marks, won't harm the paint. It conformed to the opening. Used it for years in the body shop.
    We always said we were going to call the door up. It works on staging doors too. Frank
    Paint Guru likes this.
  4. 1980gold
    1980gold
    So wedge the 2x4 in the door above the handle and push down on the top? with my hands and then up on the bottom? I just want to get an idea what I'm trying to do before I do it wrong thanks
    joe
  5. malcolm1943
    malcolm1943
    No! You place the phone book between the door and jamb just above the handle. Then push in toward the jamb at the lower corner (push hard, you have a sizable gap to close). Also push in at the top alittle as it will want to move out as you push the bottom in. After doing this check the fit and do it some more if it needs it.
    1980gold likes this.
  6. Wray Schelin
    Wray Schelin
    I have heard of this phone book technique before. Haven't had the need to use it. Please let us know how it works out for you!
  7. 1980gold
    1980gold
    ok cool thanks woulda been interesting if I used my own visual
  8. fordor41
    fordor41
    also remove the door latch on the post. Try bending the door and get as close as possible then install/ adj. the latch. saves a lot of latching/unlatching. also correct weatherstripping?
  9. el Scotto
    el Scotto
    from Tracy, CA
    I'd be interested in seeing the results as well, my Merc coupe seems to had a rough life so far.
  10. 1980gold
    1980gold
    I just got mine like 2 months ago but yeah mine too
