41 ford box for Model A cross steering?
Discussion in 'The Hokey Ass Message Board' started by jhouse88, Jul 1, 2012.
  1. jhouse88
    jhouse88
    from toledo
    there is a box here in the cl***ifieds from a 41 ford truck and it resembles a vega box as far as where the shaft placement are. i was wondering if it would be possible to configure it for cross steering. im trying to stay pre 60 for my Model a truck build and i have had no luck finding a f1 box and the price is right on the 41 box
  2. jhouse88
    jhouse88
    from toledo
    Cool. Thanks
  3. AnimalAin
    AnimalAin
    If it is a 41 pickup, it is very similar to a 40 ford p***enger car box.
  4. fordor41
    fordor41
    A '41 box will be a worm/sector box and could be fubar'd ,especially in the centered position, and can be spendy to rebuild. A vega style box may be the better choise
  5. PASTDUEBILL
    PASTDUEBILL
    It is the same as a p***enger car steering. So is the drivetrain, frame and powerplant.
  6. Detonator
    Detonator
    from santa cruz
    These boxes work great, a little larger than a Vega; there are parts available to rebuild them. I've had one in my Model A for quite awhile and it steers like ****er. Vern Tardel offers a "how-to" book on these boxes that's got a lot of helpful info.
  7. Dreddybear
    Dreddybear
    I have configured my car for this box. It's a tight fit, but a great period-correct box.
  8. 40FordGuy
    40FordGuy
    Vega,...Lots of repair pieces are available, and it's as "bolt in" as it gets.
    4TTRUK
  9. 40FordGuy
    40FordGuy
    Ps; Doing a cross steer in a Model A means adding a Panhard rod from the axel to the frame.
    4TTRUK
  10. Slick Willy
    Slick Willy
    Ive got one in my '31 AV8 roadster, works great, I rebuilt it two winters ago.
    Also I had a panhard bar on it, I took it off and the car rides alot better now.
  11. mustangsix
    mustangsix
    I have one in my Deuce. Works well, but I wasn't able to keep the one piece steering shaft because it wouldn't clear the exhaust I'm using.
    I cut the shaft and used two welded, pinned joints with an intermediate shaft to get it around the engine. You lose the ability to run the horn wire thru the shaft, unfortunately. I added a panhard to help stabilize things, but could have run without one.
    BTW, it's a worm and roller, not worm and sector. My only complaint is that I wish it were faster. It's about 3 3/4 turns lock to lock and is very light.
    OTOH, I bet that visually 95% of people wouldn't notice the difference between it and a Vega box.
    oliver westlund likes this.
  12. Dreddybear
    Dreddybear
    Nope. And while this will be debated over and over again on here, me and about 100 other guys I know will be happily driving around without em.
  13. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    Here is a thread I started:
    http://www.jalopyjournal.com/forum/showthread.php?t=650849
    Didnt work for me. BUT thats because I am running a flathead and the side of the motor got in the way too much using the A rails. It would have worked if I was using an OHV motor where all the business is up higher out of the way. Its totally easy with a 32 frame also because you have more room between the frame and the engine.
  14. Bruce Lancaster
    Bruce Lancaster
    Ford used cross steer 1935-41 without panhard anti-sway, '37-41 with this basic box. "42-8 they used the bar, not because of cross steer as such but because of using what amounted to dropped shackles. If early shackles are set right they will handle sway fine.
  15. pasadenahotrod
    pasadenahotrod
    from Texas
    From 1909-1941 Ford car and pickup springs were mounted under tension thus eliminating sidesway as a problem and having no need for a Panhard bar.
    From 1942-48 the Ford cars came stock with front and rear Panhard bars since the springs were no longer mounted in tension in order to give a softer smoother ride to compete with other makes with IFS and dual rear springs.
  16. fordor41
    fordor41
    Also '41's had a sway bar that, by design, acted as a panhard bar.
  17. U-235
    U-235
    Wow...what you can learn on this forum.
  18. Bruce Lancaster
    Bruce Lancaster
    There were several versions of "stabilizer" bars on '40-41's and on slightly earlier Zephyrs, made basically as anti-roll bars but with some mounted in such a way ast to resist sway, but they were sort of "soft", subject to bending of a spring part, in the sway direction. Sway control was mandatory on '42 up yypes because of hanging shackles.
  19. PASTDUEBILL
    PASTDUEBILL
    Next time I'm in Austin, can stop by with some shop rags and a can of mineral spirits and clean that nasty *** steering box for you Dreddybear? I would lose sleep if that was bolted to my nice bare metal frame.:eek:
  20. Kevin Lee
    Kevin Lee
    Super Moderator
    Early Ford,...Lots of repair pieces are available, and it's as "bolt in" as it gets.
  21. NortonG
    NortonG
    Going this route with my new build too.
    Should work great!
