41 ford brakes
Discussion in 'The Hokey Ass Message Board' started by 17dodgebros, Jan 11, 2011.
  1. 17dodgebros
    17dodgebros
    i have a 41 ford rear im trying to get cleaned up. the problem im having is how do i get the upper adjuster out so i could paint the backing plates. also does someone sell the springs
  2. steel rebel
    steel rebel
    Leave them in you are opening a can of worms. They usually aren't even taken out when being chromed. They are riveted in.
    LOU WELLS likes this.
  3. DICK SPADARO
    DICK SPADARO
    The upper adjusters are installed as a backing plate ***embly, they do not come apart unless you grind the swedged head off the cam. Springs are not available but you can get Stainless steel adjuster bolts. If yon want more info on the bolts PM me.
  4. custom300
    custom300
    As stated above I would leave them alone they where put in a certain way with the tabs on the inside adjustment tab. Usally one you remove them you will not beable to re-install them.
  5. seabeecmc
    seabeecmc
    Remove the adjusters for a more effective clean up. They really need to be removed for a quality chrome job. Stainless replacement adjusters are available and easy to install. Check with **** Spadaro he has them in stock. Ron
  6. 1950Effie
    1950Effie
    from no where
    Thompson garage has rebuild kits. Springs and all. Leave the adjusters in though!
  7. seabeecmc
    seabeecmc
    Please refer to the "Backing Plate Bling" thread. Ron
  8. dgasbag
    dgasbag
    from Upstate NY
    These pictures will show that it isn't as awful as everyone wants it to seem, I will post more pictures so that you can see the whole process
    gary macdonald likes this.
  9. dgasbag
    dgasbag
    from Upstate NY
    More pictures!
  10. dgasbag
    dgasbag
    from Upstate NY
    The finished product!
  11. seabeecmc
    seabeecmc
    That should take the fear out of replacing those paint chip prone adjusters. Ron
  12. Acey-Deuce
    Acey-Deuce
    This was very helpful for installing stainless adjuster kit. Thanks AH
    42merc likes this.
  13. seabeecmc
    seabeecmc
    Stainless springs are now available.
  14. Lem Chesher
    Lem Chesher
    Thank you so much now where could I get new bolts and springs!
    Regards
  15. Lem Chesher
    Lem Chesher
    How can I get a set of them. And how much
    Thank you
  16. Lem Chesher
    Lem Chesher
    Where can I get the kits
  17. seabeecmc
    seabeecmc
