Technical 41 Ford Hood
Discussion in 'Traditional Hot Rods' started by meyetoys, Jul 28, 2016.
  1. meyetoys
    meyetoys
    from New York
    Will a 41 Ford sedan hood fit a 46-48 Ford sedan? Thanks
  2. it will with the rest of the 41 clip and you will have to rework the front of the running boards
  3. meyetoys
    meyetoys
    from New York
    Thanks. I picked up a hood that I was told was off of a 47 Ford & it ends up being for a 41.
    I don't have the rest of the front clip.
  4. Tim
    Tim
    from KCMO
    It will fit it just doesn't line up with the "mustache " of the grill correctly because the shape is different. I have seen a 46-8 with a 41 hood before. You could use it in a pinch but it's probably not what your wanting long term
  5. meyetoys
    meyetoys
    from New York
    Thanks I really like the looks of the 41 front. Maybe I'll try to find the rest of the clip.
  6. Tim
    Tim
    from KCMO
    Should bolt up but I think the front axle is a little narrower than a 42-8 might be an issue, might not.
    LOU WELLS likes this.
  7. where in N.Y. are you located?
