Technical 41 Ford rubber trans mounts
Discussion in 'Traditional Hot Rods' started by Fusbc, Nov 8, 2024.
  1. Fusbc
    Fusbc
    Where do I get the rubber pads for the transmission mount on a 41 Ford coupe?
    Are they the same as the motor mounts???
  2. Hitchhiker
    Hitchhiker
    37-41 use the same mounts as the engine.
    seb fontana likes this.
  3. 19Fordy
    19Fordy
  4. Fusbc
    Fusbc
  5. 19Fordy
    19Fordy
    As a side note, don't squish the rubber down by over tightening.
    Just make them snug plus about a 1/2 turn more to eliminate all play.
    Be sure to install the cotter pin, if there is one.
  6. Fusbc
    Fusbc
    Great! Thanks! Do I tighten the motor mounts the same way???
  7. alchemy
    alchemy
    Yes. Don’t buy cheapo mounts. I bought some from Speedway once and they were crushed down within a couple years.
  8. jet996
    jet996
    from WY
    X2 on speedway mounts. I used Ch***is Engineering on my last ones, much better material.
  9. 19Fordy
    19Fordy
    Here's a good rubber mount.. I like them because they have the metal band around the cir***ference of the rubber to help keep its shape. Plus, they use the correct bolt.
    Search results: 3 results for "1940 ford engine mount" – Bob Drake
    Here's a photo of the rubber motor mount biscuit (without the metal band) like it was originally made by Ford. I installed the chrome castle nut.
    Same biscuit is on the transmission mount. I used the steering stop acorn lock nut. Car is 1940 Ford.
    jet996 likes this.
