Projects '41 Ford Tudor
Discussion in 'The Hokey Ass Message Board' started by vintagedream, Oct 24, 2011.
  1. vintagedream
    vintagedream
    Body off the frame and trying to get as much as possible done before the cold weather sets in. My garage is heated but I like to work with the doors wide open when I can. The car was originally from California so the frame had little rust, just needed some wire brushing and an application of POR15. After much second guessing I decided to go with the buggy spring and triangulated 4-link rear. I found a rear end from a 1968 Ford F100 that is within 1/2 inch of the width of the original banjo rear. The picture shows the original spring but after I put the body back on the frame I had a new main leaf made with reverse eye to lower the ride height a bit. Before the body went back on I plumbed the rear brakes and also ran a wiring harness to the back. I'm not real happy with the angle of the upper links but if I have to I'll install a panhard rod as well.
  2. vintagedream
    vintagedream
    Engine is a 1981 Buick 350 with a TH350 trans. I chose it because it was available and I wanted to be different. No plans to tear the engine down but I have ordered new timing gear and chain set, water pump and timing chain cover. The picture shows the original timing cover which I had plans to use but it has too much corrosion. Headers are ******, they came with the engine/trans deal but I had to modify them. The right side not so much but on the left I had to cut three of the pipes and re-route them to clear the steering box.
  3. vintagedream
    vintagedream
    Sorry I'm no good at build threads or updates. Here's a picture of my paint job which I'm doing in sections.
  4. 48ford
    48ford
    Looks like it's going to be sweet!!!!!
  5. fordor41
    fordor41
    Am not an expert but I'm wondering what will happen with the tri-4 bars and the transverse spring. Short bars may want to twist the spring with the up/down motion. The original torque tube, with it's long length, minimized the "arc" at the diff and didn't twist the springs a lot. Usually with a 4-bar coils/coilovers are used.Good luck
  6. need louvers ?
    need louvers ?
    Trianglulted four links are nothing new and will work ok with a cross leaf spring. Ideal would have been a Pete&Jakes style traction bar set up because its length mimics the original torque tubes suspension arc, but what you have will work just fine. You shouldn't need a panhard rod with the way you have stuff set up. Just keep an eye on the shackle angle. Ideal is 45 degrees, shallower isn't as good.
  7. vintagedream
    vintagedream
    Thanks, actually when I installed the new main leaf it fixed that shackle angle problem. Now I have 45 degrees with the body back on.
