Projects 41 plymouth coupe 392 hemi build thread
Discussion in 'The Hokey Ass Message Board' started by farmer12, Apr 7, 2010.
  1. Wow OahuEli! Great work!!! I like it!
    Now farmer12, GET TO WORK!!!! haha!
    OahuEli likes this.
  2. OahuEli
    OahuEli
    from Hawaii
    You're quite welcome! I've been following this thread for awhile and your idea for the dash fits the car well. Looking forward to more progress pics.
  3. OahuEli
    OahuEli
    from Hawaii
    Thanks!
  4. farmer12
    farmer12
    Going to work on the car again tomorrow. Haven't decided whether I'll do some more leading or continue with the dash..... choices, choices.....
  5. farmer12
    farmer12
    Got back to doing some more leading today. I nearly finished the concerned area, with probably only an hour or two required to completely finish it off. From there I'll probably continue with the dash and the top of the bulkhead/firewall where some welding is required.
    What has amazed me is how much time has gone into the leading so far. I'm probably looking at a total of 40 hours. But enjoyed every minute of it. It sure was a great learning experience!
  6. Are you going to fill the indentation in the door to match the body?
  7. farmer12
    farmer12
    Yes, I'll be filling the top trim line as well, only leaving the trim from the front to the back of the car. Never really understood why the extra belt line was required. Anyway, I'm aiming for a clean look with only some of the trim remaining.
  8. farmer12
    farmer12
    Just a little side track to my build. Went to a hot rod/custom show today, checked out a few cars. Some were nice, some average. Only a few cars were show quality though. Anyway, had a good time with my buddy Stef, who came along for the ride. Here is just a short impression of today. Going to work on my car again tomorrow, after having received some further inspiration.(of how to do it and not how to do it!)
  9. farmer12
    farmer12
    Got back to work on the dash again today. I cut some more off the dash and test fitted the center piece again. My buddy Martin rounded the lower edges for me. Made a small lip on the top and I clamped it into place. Spot welded the top and lower edges. I drew the gauges on it to ensure they are centered and proportional.
  10. Finnrodder
    Finnrodder
    from Finland
    Looks good so far.You are going to do the side pieces with beadroller?
  11. farmer12
    farmer12
    Haven't decided if I'm going to beadroll the sides or not. Another option is to use some half steel rods and mount them. Either painted in the dash color or have them chromed. Still thinking about it.....
  12. farmer12
    farmer12
    I cut out some cardboard with the same radius as the lower part of the window, to see whether or not a split window in the back would look good. Considering the front window is also split and the rear a fairly large piece of gl*** (I can hardly see out of it anyway), a split window may just be the way to go. I'm not trying to be different, I just want it to look good and proportional to the rest of the car. I may just leave it on the car and see if it will grow on me. (or not)
    What do you guys think? :confused:
  13. milwscruffy
    milwscruffy
    IMHO, with the size of your rear side windows the split rear tends to make it too busy looking to me. I'd leave well enough alone if it were me and i can be a real tin butcher myself when need be. :cool:
  14. my vote would be no on the rear window split. neat idea and a lot of cl***ic cars have them, but the curves on the top of your car are so nice I just don't see the split accentuating the lines. But again, that's just me.
  15. skiviskaves
    skiviskaves
    I agree. I think the window looks perfect as is.
  16. 4Door54
    4Door54
    from Nor*Cal
    Another vote for one piece.
  17. Finnrodder
    Finnrodder
    from Finland
    Same here,but i guess it could look better on the front window
  18. Johnny C.
    Johnny C.
    Great build and awesome car. Such a cool chop and look. You are doing a amazing job on it and I can't wait to see it finished.
  19. Frankie47
    Frankie47
    from omaha ne.
    I personally don't think the rear window is "oval" enough to pull the split look off, to me it would like an afterthought not something that belongs.
  20. swazzie
    swazzie
    Okay man, i think two things ; 1, the window should follow the contour of the roof and shouldn't be flat , and 2, split the windows but only if you fix the contour . it's a sweet lookin ride that has alot of individual design traits that aren't quite the same as ford or chevy body lines and deserves to be customized as such . Split the window , give it it's contour back. Awesome ****ing build though , really, really inspiring... thank you for sharing this....
  21. robleticia
    robleticia
  22. thinkfink
    thinkfink
    i second that....but despite that...great job!...am green with envy:D
  23. farmer12
    farmer12
    Went back to work on the dash once again. Worked out the shape of the metal.on either side of the clock cluster. Started working out the profile as well. Decided not to beadroll. I'll be using 3 br*** strips each side and screw them on from behind. Then finish it off with lead so it will flow into the dash. The whole dash (front side) will be painted and these strips will look as part of it. Final shaping and cutting still needs to be done. I've proceeded to shape the left side of the dash, still needs to be a little more rounded. Hopefully I'll have some time to finish most of it this week. Damn this thing takes long! (but worth it in the end)
    And with regards to the rear window, I think I'll leave it as a one piece. Like some of you have stated, it's not oval enough to be split. Thanks for the comments and advise guys! Very much appreciated! Thanks, Eric
  24. farmer12
    farmer12
    I was back at work on the dashboard again. Shaped the right side today, taking a long time to get it just right. Got a sore right arm now from the hammering. I cut out some more of the original dash and did a test fit. (also with "stripes" on either side. Fine tuning the shape of these will be done next time)
  25. OahuEli
    OahuEli
    from Hawaii
    I like the idea of curving the inner part of the strips around the gauges. That dash is gonna look good!
  26. farmer12
    farmer12
    Thanks OahuEli. I think I'll finish the strips once I've made the holes for the gauges and have the correct radius.(outer trim of the gauges). They will look less pronounced once they are mounted and painted in color. Hope to finish the whole dash next week.
  27. rubens
    rubens
    :D See ya again next year.....But then, WITH both the cars..:cool:
    Groeten Ruben
  28. farmer12
    farmer12
    I'll be there next year for sure, and with the car this time!
  29. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    Car is coming along nicely, good job man.
  30. desoto52
    desoto52
    from holland
    checking your build..i can only say.. much respect..looks like one of hollands finest..keep making the right decisions..its getting there..greetz
