41 Plymouth SB Mopar Engine Swap
Discussion in 'The Hokey Ass Message Board' started by rockable, Aug 1, 2010.
  1. rockable
    rockable
    I will let the painter paint the firewall the same color,as the rest of the exterior, Nissan Merlot Metallic.
  2. Hogman
    Hogman
    from Dallas, TX
    Great work Rockable. You guys with 40-41 Plymouths are becoming quite a large club here on the Hamb, which is great to see. One of the best looking cars ever made imho.
  3. yetiskustoms
    yetiskustoms
    looks really clean, hope to be doing a similar install on my 54 plymouth soon
  4. rockable
    rockable
    Thanks, guys. This is not my first restoration but it is my first hot rod build. I am really enjoying it and trying to do a good job. Thanks to all you Hamb'ers for the advise and encouragement!
  5. mobildave
    mobildave
    from Colorado
    Love the shroud and lip seal.
    I just ***umed that there just was not enough room for the fan there and had planned on using a pusher up front. I really don’t like the idea of it up front it just does not look good through the grill...
    What do you have planned for the clutch and break peddle seals to the floor boards? I have been looking for something like a miniature shifter rubber boot or bellows type design.
    Mobildave
  6. mobildave
    mobildave
    from Colorado
    From where I sit that elephant must be starting to taste pretty good:D
  7. rockable
    rockable
    I am going to try some pedal seals I got from Andy Bernbaum, most likely. Mi am also going to check the Steele Rubber catalog for a better solution.
  8. rockable
    rockable
    Tasting better and there is not nearly as much left. :D
  9. 50dodge4x4
    50dodge4x4
    Elephant is an acquired taste, as you eat more of it, the better it gets. The problem is, once a project is done, a guy just can't seem to resist the taste of elephant, and goes and gets another project. :D
    Keep plugging away Rock, the Plymouth is looking good. Gene
  10. rockable
    rockable
  11. BrerHair
    BrerHair
    Well said, Gene. This is a hot rod Universal Truth, methinks. The journey is what it's all about. You get there and you say . . . hmmm, think I'll turn around and head back. :cool::D
  12. rockable
    rockable
    I made up some pieces from 20 ga. sheet metal and cut a 1 1/4" hole in them. Then I drilled holes so that I could use as many existing holes/nuts as I had. Had to weld 3 additional nuts to the bottom of the floor. The stock seals will be glued to these pieces.
    I think they turned out pretty well.
  13. rockable
    rockable
    I also made a cover to hide the hose connections to the AC on the inside of the car. I didn't want to be looking at 4 ugly hoses poking through the kick panel. I will have this upholstered when I get to that stage.
  14. farmer12
    farmer12
    Brilliant work as usual Rock, looking good. The finish line is near.
  15. BrerHair
    BrerHair
  16. rockable
    rockable
  17. mobildave
    mobildave
    from Colorado
    Nice... Now if I could just figure out how to get that kind of response to all of my questions in life:confused:
  18. n847
    n847
    Looking good...I like the kick panel cover, should stay nice and clean!
  19. rockable
    rockable
    Thanks, n847!
    Guys, I will be working on the Chevy for a couple weeks so that I can drive it to GG Nashville. Then, I should get back on the Mayflyer.
  20. n847
    n847
    rockable...a couple weeks expired about 6 months ago? LOL
  21. Hemiken
    Hemiken
    from Australia
    Hi, i just jumped in to say nice car and is it up and running. Another Mopar in a Mopar, great to see. :D
  22. rockable
    rockable
    No. Unfortunately, I got sidetracked with a 54 Chevy that was supposed to be "good to go". It was not and I spent 6 months sorting it out. Then, my 86 Silverdao's engine took a dump and I have been finishing that up.
    I hope to crank back up on this one later in this month.
  23. Hemiken
    Hemiken
    from Australia
    That will be cool ;) , do you have any picture of your car from front on you could share please ? :D
  24. rockable
    rockable
    I'm baaaaaack! After a pretty long hiatus, I got back to work on the Mayflyer this week. The more I looked at that stock firewall, the more I hated it. So, I cut it out and put my new bead roller to use to fabricate a new one. I think it looks way better than the original plus it gives me a little extra room around the engine.
    What do you think? Sorry, but I didn't have time to brush all the welds but you can tell what it looks like.
    Happy New Year everyone!
      218.9 KB
      230 KB
      191.4 KB
      436.2 KB
      439.8 KB
      175.4 KB
  25. farmer12
    farmer12
    Great to see you're back at it Rock, I did kind of miss it. The firewall came out looking great!! Next thing you now you're going to attack the area above it! :D:rolleyes:
  26. need louvers ?
    need louvers ?
  27. BrerHair
    BrerHair
    Good to see you back at it, nice work.
  28. n847
    n847
    Looks great! I always like the contours of a stock firewall, but this is great work! Do you're valve covers clear the firewall without dimpels?
    Glad to see you back at it keep us posted!
  29. Hemiken
    Hemiken
    from Australia
    Nice update, nice straight lines too.
  30. n847
    n847
    Never mind after looking again I realized that you cut the "bulge" off!
