Technical 41 to 46 Ford Vent Window Interchange
Discussion in 'The Hokey Ass Message Board' started by unfinished, May 23, 2023.
  1. unfinished
    unfinished
    I am building a 1941 Ford Business Coupe but do not have the vent window ***emblies. Can someone tell me if the vent window ***embly from a 1946 coupe will fit?
  2. topher5150
    topher5150
    They should all be the same. There are two different vent styles, push-out, and crank-out. Also, you'd have to get one from a business coupe or a four-door sedan.
    alanp561 likes this.
  3. rustythumb32
    rustythumb32
    '41 is different. (no divider bar)
    rodncustomdreams likes this.
  4. unfinished
    unfinished
    Thanks for your reply. I have access to a couple of '46 coupes for parts so I might as well go ahead and see what I can do to make em work! I'm installing Vintage Air on this build so I don't care if the vent window actually open or not.
