41 Willys Project
Discussion in 'Off Topic Hot Rods & Customs' started by Ronald Massey, Jan 16, 2026.
  1. Ronald Massey
    Ronald Massey
    I have a 41 Willys I just acquired. It's an AC body on a custom ch***is. It has a narrowed 9 inch with 3.73 gears and 31 inch tall tires. I have a stock bore 400 sbc to put in it. The current setup has 5 cc flat top pistons sitting .006 in the hole with .039 compressed headgaskets. It has Dart Pro1 215 cc heads with 64 cc chambers and a Herbert C6KF solid roller camshaft duration @ .050 250/260 lift 600/625 with 1.5 rocker and a center of 106 degrees. It has a **** forged crankshaft, eagle forged 5.7 rods. I'm wanting to make this engine more street friendly because this car will be a street car. What would be the most budget friendly option to do this? Cam swap? Cam and piston swap? When I swap cams I want to go back with a solid roller to use my existing parts. Sorry for the lengthy post and thanks.
  2. rusty valley
    rusty valley
  3. 34Phil
    34Phil
    what trans? if auto all you may need is a higher stall. if stick try it before you tear into it. After all, it's a Willys.
  4. Ronald Massey
    Ronald Massey
    swade41 and chryslerfan55 like this.
  5. Ronald Massey
    Ronald Massey
    I have a 4l60e with a 2000 stall converter. I figured I'd have to get a bigger stall. This motor was in a car setup for drag racing and ran on race fuel. Do you think it would be safe to run on 93 with this current setup with a bigger converter?
  6. 34Phil
    34Phil
    compression should be around 10:1 if current engine is 350, 11.4 if 400. 10 works, 11.4 doesn't.
  7. Ronald Massey
    Ronald Massey
    Yeah it's a 400.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    moved to the off topic forum. Tubbed pro street cars are off topic on the main board, and the "traditional customs" forum is reserved for the most period correct custom cars built in the style of 1965 and before
  9. Ronald Massey
    Ronald Massey
    Okay I understand. Sorry and thanks for correcting.
    chryslerfan55 and Moriarity like this.
  10. Ronald Massey
    Ronald Massey
    After entering my numbers in a compression calculator, I've come up with 11.37 static and 8.43 dynamic compression. From my understanding if I cut a few degrees of timing I should be able to run on premium pump gas. What's your thoughts on this?
  11. mustangsix
    mustangsix
    Almost every Willys seems to be built like a g***er. I'd love to see one more street oriented.
    It would still be fast as hell.
    chryslerfan55 and Ronald Massey like this.
  12. 6sally6
    6sally6
    With11.3 CR your gonna need a cam with a tight LSA like 108* to bleed off some compression at low speed.
    You go with a 'shelf grind' with 112* OR possibly 110* and you risk spark knock even when using 93 octane gas.
    Street engine does NOT need a WILD lift number either. It stresses the valve train needlessly.
    I'm a big fan of Delta Cams OR Howard Cams.
    Get a custom ground stick and you should be happier.
    Duration.....my guess (like all the above 'advice') maybe 230* intake 235/240* exhaust.
    Install an adjustable cam gear whichever way you go.
    Your present camshaft retarded a few degrees may make it more streetable !?!
    Let us know which way you go.....
    6sally6
    SS327 and chryslerfan55 like this.
  13. Onemansjunk
    Onemansjunk
    from Modesto,CA
