Hot Rods 410 MEL
Discussion in 'The Hokey Ass Message Board' started by willsullivan, Dec 1, 2019.
  1. willsullivan
    willsullivan
  2. willsullivan
    willsullivan
    Ive heard they can get pretty crazy, over 500 ci, though ill probably stay with this block because its already magna-fluxed and crack free. I bought it machined and done for 1500 bucks, so i might run it as is and start ac***ulating parts for stage 2, which will consist of stroking it out, 6-71 blower, higher profile cam, and headwork.
    loudbang and Boneyard51 like this.
  3. Elcohaulic
    Elcohaulic
    I never heard of a MEL, (Mercury, Edsel, Lincoln).. That sure is a nice looking mill.. Fords always seemed so exotic to me (GM guy), I know this much, they are too expensive for me..
    willsullivan likes this.
  4. Boneyard51
    Boneyard51
    You put a good cam, four barrel, recurve the dist, big daul exhaust. It may surprise you!
    Bones
    loudbang and willsullivan like this.
  5. Jet96
    Jet96
    from WY
    I like them, historically significant, big inches, front distributor, right hand starter, FE bellhousing (on the early ones). Perfect hot rod stuff!
  6. sunbeam
    sunbeam
    loudbang, willsullivan and Jet96 like this.
  7. v8flat44
    v8flat44
    I rode in a 58 Edsel back in the day with that engine.......the tire stores loved them.....smoke'n they was...once they hooked up, it'd pin ya to the seat.
  8. lippy
    lippy
    from Ks
    We had a 58 Edsel Bermuda 9 p*** wagon. 361-303 hp. We drove it back and forth from Calif to Ks a few summers. Yeah it would get after it pretty good for a big wagon. I had a 67 Lincoln 2dr hardtop with a 462 it was a brute. And made pretty good mileage on the hi-way. Good engines both of them. Lippy
  9. I have a 430 Mel. mine is a 2 bbl engine. I last ran it in a 56 pickup with a granny 4 speed attached to it. I used the regular FE flywheel and never had any vibration or balance problems. Mel engine 004.JPG
  10. speedshifter
    speedshifter
    In about 1959 I modified a 430, stuffed it in to a 57 Ford. Early ones had FE bolt pattern on rear of block, FE flywheel & adj rocker arms from FE fit. If you raise max rpm you will need stronger con rods. I used stock rods, had them Magnafluxed, yet one broke in the middle. I then phoned Holman Moody. They said that failure was common & I would need to spend big money for after market rods. Greg
    loudbang, Old wolf and willsullivan like this.
  11. sunbeam
    sunbeam
    There is a guy on ebay selling a complete engine kit. Finding some one with the plate to bore it will be tuff.
  12. FrozenMerc
    FrozenMerc
    The plate wouldn't be that big of a deal. Same bore spacing as a 429/460, just need new bolt holes.
    Be very aware of the E-bay kits. They most likely are re-selling Egge kits and use a flat top piston that will ruin compression ratio and combustion performance.
  13. The plate would need to be angled to square up the bore with the deck. the combustion chamber is in the cyl bore.
    sunbeam and loudbang like this.
  14. FrozenMerc
    FrozenMerc
    Good Point. Brain fart on my part.
    Boneyard51 and loudbang like this.
  15. Boneyard51
    Boneyard51
    Not really, when I had my 430 bored, many moons ago, the machinist, Louis, had to set up his boring bar at an angle. I can’t remember how he did it, but I know he *****ed a little at this 16 year old kid bringing that MEL in there. Back then , he didn’t use a plate.
    Bones
  16. Karl_William
    Karl_William
    So how'd it turn out?
