Technical 42-47 disc brakes ?
Discussion in 'Traditional Hot Rods' started by carpunker, Jul 29, 2019.
  1. carpunker
    carpunker
    i tried the search but nothing usefull found
    And I'm sure this is a common thing?
    So what's the most economical adaapt and over come junkyard swap way to get disc brakes on a 42-47 ford 1/2 ton or off the shelf kits I guess also heard sometbing about windstar front ends ??
    Sorry if this is the wrong area to ask admin feel
    Free to re locate .
  2. Doublepumper
    Doublepumper
    from OR-WA, USA
  3. Cosmo50
    Cosmo50
    https://www.speedwaymotors.com/Complete-Disc-Brake-Kit-1937-48-Ford-5-on-5-1-2-BC,1997.html
    This is the kit I went with on my 41 Tudor. It fits the 1/2 ton also. What is nice about this is it keeps the stock 5 on 5-1/2" bolt pattern and all the parts are off the shelf. It uses early F150 rotors, GM calipers and pads. And the bearings and seals are easy to get too.
    The only thing bad about this kit is you can't use it with the bolt on steering arms. So if you have a dropped axle, you will have to use stock spindles with the arm bent to clear.
    WB69 and topher5150 like this.
  4. carpunker
    carpunker
    Thanks guys are any of those parts junk yard available or rock auto etc and just buy the brackets?
    I realize it's cheap but it soon gets out of hand so saving here and there also ads up
    While on the subject what master cyl are you using? thanks again
  5. topher5150
    topher5150
    you can buy just the adapter brackets from speedway and they tell you which vehicles the rotors and calipers come from. All common parts that you can get from any auto parts store.
  6. Cosmo50
    Cosmo50
  7. treb11
    treb11
    You can sometimes find the kits in the Speedway "garage sale" pretty cheap cuz they're returned and may be missing a bolt or 2.
    Sent from my SM-G965U using The H.A.M.B. mobile app
  8. Doublepumper
    Doublepumper
    from OR-WA, USA
  9. 56don
    56don
    Some times the kit is cheaper in the long run. By the time you get all the little parts and run around searching junkyards for parts it adds up to more. Plus the junkyard parts will need to be rebuilt and the kits have all new or rebuilt parts.
    WB69 likes this.
  10. WB69
    WB69
    from Kansas
  11. carpunk
    carpunk
    Thanks guys really appreciated
    Now I need to look into steering and brake master cylinder options
  12. Doublepumper
    Doublepumper
    from OR-WA, USA
    Master cylinder will depend on what brakes will be used. The steering box is completely rebuildable. I rebuilt mine using parts from Mac's.
  13. carpunk
    carpunk
    Unfortunately my steering box is completely missing.
    Brakes will be a disc kit for front and prob drums rear and was hoping to be able to find brakes on something factory to use easily found at the jy or parts store ? Steering same deal I
    Do have the coloumn but want a collapsible type
    Easily wired to basic aftermarket harness
  14. carpunk
    carpunk
    Ok my friend called thinks
    He's found the steering box and coloumn is there a way to seperate the coloumn from the box on these and ad a rag joint or collapsible coloumn?
  15. Doublepumper
    Doublepumper
    from OR-WA, USA
    Yes, you'll have to cut through the column, leaving shaft stubs on each end, then install bearings or bushings in the tube ends to support the shafts.
  16. patterg2003
    patterg2003
    The Speedway kits seems reasonably priced. The sum of the parts all the parts purchased separately like the brackets, rotors, calipers, pads., bearings plus all the misc. parts will likely be higher than the kit. Speedway have $20 off on orders over $250.
  17. topher5150
    topher5150
    And free shipping over $100
    Sent from my moto z4 using The H.A.M.B. mobile app
