Technical 42-48 Columbia in a 39, yes? No? Don't even think about it?
Discussion in 'The Hokey Ass Message Board' started by theHIGHLANDER, May 4, 2025.
  1. theHIGHLANDER
    theHIGHLANDER
    So with severely crippled searches lately (never what you're looking for) it seems the 42-8 Columbia is 2" wider than the 37-41. I stumbled upon some stories that said a 42-8 was used in their earlier cars, yet even with a spoon of salt vs a grain I can't seem to wrap my head around the effort. I have the extra room to push outward with tires but maybe not in the future if I went generic 15X6 wheels and radials for long trips. You know, don't burn bridges. I smell unseen WTFs in this stew of ideas and caveats. Undue worry or run away in the other direction? I'm currently equipped with 30" tires and 3.78s. Not hateful, but a Columbia would make 70 mph pretty cozy and right now I feel like 60-65 is the harsh reality. Fresh stock 239 flatty, not much hop up planned over twice pipes and dual carbs.
    Ok, ok. There might be a decent deal on one but it's a 42-8. If it's just nuts and bolts then...?
  2. 42merc
    42merc
    Actually the 42-48 is an 1-1/2 wider, 3/4" per side. Drive shaft & torque tube from the 39 will interchange. Use the 39 radius rods with a 3/4" spacers at the backing plate.
    Not to worry.
  3. alchemy
    alchemy
    I’ve got an unassembled 41 Columbia I’d sell. Would need a donor stock 41 rear to make it complete though.
  4. theHIGHLANDER
    theHIGHLANDER
    (ears perked up) So then here's another thought. All the Ford stuff in a standard banjo like axles, bells etc work in sync with the Columbia stuff on the other side. My race car days had me modifying housings on a truly regular basis. Is it crazy to think I could get a standard 37-41 right side bell and move the Columbia stuff to it? The right side axle is just a Ford axle poked in thru the good stuff? No worries at all about modding up a bell if that's also a reasonable thought.
  5. theHIGHLANDER
    theHIGHLANDER
    I may end up scrapping this idea for now. While perhaps ultimately doable there's a finance angle involved that I'm not sure I want to tackle. The peripherals add up fast.
