'42 Ford pickup steering box
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by alpinetom, Oct 21, 2011.
  1. alpinetom
    alpinetom
    from utah
    I'm restoring a '42 Ford pickup. Trying to remove the steering box. How do I disconnect it from the steering column? I've disconnected everything else. Thanks.
    Alpinetom
  2. wbrw32
    wbrw32
    TOM...Welcome to the HAMB,,,,Please read the "sticky"at the top of this page...INTRODUCE YOURSELF..then post your question on the main message board....But you cannot disconnect the box from the column.Pull the steering as a unit
  3. Dreddybear
    Dreddybear
    As he says^ With it all removed and the column lock off and the steering wheel off the column should slide off the steering shaft.
  4. el Scotto
    el Scotto
    from Tracy, CA
  5. PORKCHOP76
    PORKCHOP76
    from iowa
    ^^^ thats what i was thinking.
  6. You will have better luck around here after a proper introduction.
