Hot Rods 427
Discussion in 'The Hokey Ass Message Board' started by Deuces, Apr 27, 2021.
  1. Something about a big block dressed in only what the factory put on them, says "We mean Business!"
    Boneyard51, loudbang and Deuces like this.
  2. MeanGene427
    MeanGene427
    from Napa
    Daytona 1964 backups
  3. MeanGene427
    MeanGene427
    from Napa
  4. MeanGene427
    MeanGene427
    from Napa
    This one is for all the yayhoos who crow "Put a Chebbie in it". No.
  5. Beanscoot
    Beanscoot
    Why on earth would Ford put those log manifolds on a 427? Maybe to keep out dirt until the cast headers shipped with the engines were bolted on?
    Also neat to see they have alternators, in 1964. Alts were optional, becoming standard in '65.
  6. swade41
    swade41
    from Buffalo,NY
  7. DDDenny
    Any guesses?
    chryslerfan55 and Deuces like this.
  8. Fordors
    Fordors
    chryslerfan55, loudbang and Deuces like this.
  9. loudbang
    Very Rare :)
    And the Best and First
  10. Deuces
    Deuces
    I wonder if we should start a thread on the 428...????..... Pontiac and Ford????
    What sez you's guys?????...:)
  11. Go for it mate :cool:
  12. topher5150
    topher5150
  13. j hansen
    j hansen
  14. Deuces
    Deuces
  15. One last comment....
    NHRA split the Mopar Hemi super stock cars out into their own separate cl*** a number of years ago because of the Hemi's performance advantage over the wedge-head motors. I've often wondered that if Ford had built the minimum number of Cammer-powered cars to go head-to-head with them how that would have played out.... They both have hemi heads....
  16. Deuces
    Deuces
    The Fords would chew up the mopars.... :D
  17. saltflats
    saltflats
    from Missouri
    What size where the inline Holley carburetors on those 427?
  18. FrozenMerc
    FrozenMerc
    Too bad the Ford 427, really displaced 425 ci.....
    Oh well. They sure are pretty.
    Let's not forget about the other 426, or round up to 427 if you want. The GM 6-71.
  19. DDDenny
    A bit on the rare side, Fords' Tunnelport" headed 427.
    Disregard the SOHC for the moment
  20. MeanGene427
    MeanGene427
    from Napa
    There were different sizes, Ford set them up carefully for each combination. IIRC the early low riser "C" carbs were 540 cfm (?), and there were 652s, 715s for the High Risers, and 780s for the Tunnel Ports
    loudbang, Deuces and saltflats like this.
  21. saltflats
    saltflats
    from Missouri
    Thanks, Sometimes I second guess myself on the choice I made for the stroked 428 I have been working on.
  22. Hot Rod Dan
    Hot Rod Dan
    from Texas
    Maybe a little bigger than 427.
    427 sleeper, 54 ford coupe and Deuces like this.
  23. Hot Rod Dan
    Hot Rod Dan
    from Texas
  24. Joe Travers
    Joe Travers
    from Louisiana
    Deuces likes this.
  25. Deuces
    Deuces
    L-88.... 562 horsepower with a set of ******s and a little tweeking of the "stock" carb....
  26. Boneyard51
    Boneyard51
    They didn’t put those long tubes on, because they would break easily. Even just setting the engine on them. They shipped them beside and put the logs on to keep **** out. Thst is my opinion......lol
    Bones
    Deuces and loudbang like this.
  27. Hot Rod Dan
    Hot Rod Dan
    from Texas
    I'm hoping to get in that neighborhood with a "L-88 tribute" engine I put together. It's got L-88 service replacement heads, bowl ported w/2.30 intakes, GM dual plane intake, less compression (10.2 for pump gas), more cam .589/.601 roller and more displacement (468). Not a true L-88, but it's got the look and should be fun.
    saltflats and Deuces like this.
  28. FoMoCo had alternators in '63 too. I recently bought a '63 Merc full-size instrument cluster with full gauges and the ammeter is marked 'Alt', not 'Gen'.
  29. Joe Travers
    Joe Travers
    from Louisiana
    I imagine the same thing that happened in NASCAR..........;)
    Joe
    Deuces likes this.
  30. Maybe, maybe not. NASCAR demanded that Ford sell 500 Cammer-equipped cars to the 'general' public, a impossibility for multiple reasons. NHRA only required 50 cars to attain 'legality', a number that the racing community could have absorbed. Ford certainly had the available motors after NASCAR banned them, they just needed to turn Dearborn Steel Tubing loose...
    Deuces, loudbang and 54 ford coupe like this.
