440 rocker arms
Discussion in 'The Hokey Ass Message Board' started by EARLYHEMIBILL, May 13, 2013.
  1. EARLYHEMIBILL
    EARLYHEMIBILL
    from ?
    I am having issues with some rocker arms on a 440. I got a set of aftermarket rocker arms for my 440 Mopar and they seem to be a little short. It looks like they are a little short on the valve tip end. Does anyone out there have a set of 440 rockers that they could measure and let me know the distance between the center of the rocker shaft and the center of the roller tip pin? Thanks in advance, Bill
  2. stillrunners
    stillrunners
    from dallas
    bump....can't get to mine.....
  3. toolz1175
    toolz1175
    from IL
    Can't imagine why they would be too short, other than a severe geometry problem. Is there any way they sent you the wrong ones? Most of my experience is with B/RB engines, but is there any possibility that you have small block rockers? I thought the shaft was the same diameter, and the rockers were shorter. It's also possible that I don't have a clue.
  4. Normbc9
    Normbc9
    Which 440" MOPAR pre-'76 or the one built for them after the GM-Ford financial save of '77? They are vastly different. But MOPAR continued to furnish the California Highway Patrol with 1,000 new 440's every year until 1988. All were I-H manufactured engines. Check on this and you may have the I-H rockers. Their engine was really known as a 446.
    Normbc9
  5. mohr hp
    mohr hp
    from Georgia
    Alright Norm, I'll bite...where did you hear all of this?
  6. 73RR
    73RR
    Yup, you, me and a few thousand other guys will be interested in the answer...
