Technical 454 ouch...
Discussion in 'The Hokey Ass Message Board' started by southerncad, Aug 30, 2015.
  1. southerncad
    southerncad
    Hard to imagine but this happened to my friends 454 that has never been over 4,500 RPM's and the rebuild is about 5 years old....what do you think happened, other than the obvious?[​IMG]
    • Looks like it's image link broke.
  2. Ebbsspeed
    Ebbsspeed
    I can't see any obvious damage.
  3. Put your specs on Gawd. :D :D
    @southerncad considering that your pic doesn't work why don't you articulate it a bit more. ;)
  4. southerncad
    southerncad
    Take a look at the pic now!;)
  5. I think there was an Oil pan failure!!! It did not hold the rods in!!!
  6. Looks like the connecting rod cap ether broke or wasn't torqued to specs.
    I see at least one stud is still in the connecting rod but there is not a nut in sight.. HRP
    afaulk likes this.
  7. 1. Install rod caps in proper direction
    2. Install rod cap nuts. Tighten snugly
    3. Torque all rod cap nuts to spec.
    Two out of three ain't bad, huh?
    INVISIBLEKID likes this.
  8. Sometimes actually more often then not the rod bolts are stretched beyond what is acceptable but the average builder seldom checks them. bad rod bolt equals disaster in the making.
  9. squirrel
    marine engine?
    falcongeorge likes this.
  10. my guess is they over torqued the rod bolts
  11. volvobrynk
    volvobrynk
    from Denmark
    Aka boat anchor? Lol
    Something bad happening!!!
  12. squirrel
    cast oil pan, never seen them used on car or truck 454s. Looks very boat like.
    and yeah, it's probably boat anchor material, but you better have a strong winch to get it out of the water when it's time to sail.
  13. Rusty O'Toole
    Rusty O'Toole
    No doubt about it, when the rod is sticking thru the oil pan, time to rebuild or replace the engine.
    49ratfink likes this.
  14. stimpy
    stimpy
    if it was a gen 6 marine motor the rod bolts stretched and failed .
  15. slowmotion
    slowmotion
    "Lou-seeee! you got some esplainin' to do!!"
    :D
  16. Nope high end mouse house. A picture window is a very high dollar option in that subdivision. :D
    stimpy likes this.
  17. Dan Timberlake
    Dan Timberlake
    Can you get pictures of the crank, the rod and cap and the other rod on that journal?
  18. Atwater Mike
    Atwater Mike
    This is (was) a Marine OR an Industrial engine. I have one that is the same color, aluminum pan, too.
    Stretched rod bolt, possible and probable; loss of elasticity loosened the nut, and off it came.
    Also possible is that nut (and possibly others) was installed upside down, OR had a scarfed surface, for whatever reason. (the 'why' of installing new con rod nuts on type l and ll VWs. After torqueing, the nuts were 'staked'...many general mechanics just re installed them with a slight 'bump' on their contact surface where they had been staked, and torque-and-stake to 'fly 'em'...
    These were the ones that came back in 75-1,000 miles with a rod through the case.
    Funny how some shit is all the same...:eek:
    czuch az likes this.
  19. Blow-by??? o_O
    The little man with the hammer in there finally broke out... :p
  20. stimpy
    stimpy
    your sick ....very sick , does it come with a porch too ??? :rolleyes:
  21. Positive crankcase vent for sure.
  22. Cap-ectomy?
  23. southerncad
    southerncad
    Thanks for your responses, and yup a marine block, I figured the rod cap bolt had stretched and knocked the nut right off....time to fix it now...
    And Beaner, I agree with that window being an expensive addition:D
  24. Jalopy Joker
    Jalopy Joker
    "Break On Through - To The Other Side" (courtesy of The Doors rock group)
    stillrunners likes this.
  25. wsdad
    wsdad
    The HOA will allow either a Porch or a Ferrari.
    volvobrynk likes this.
  26. spooler41
    spooler41
    For me the missing rod cap nuts ,says it all.
    ............................ Jack
  27. 57JoeFoMoPar
    57JoeFoMoPar
    I'll concur with the rod bolt failure. IMHO if the end cap failed it would have just split and twisted out. The ARP rod bolts are so cheap, I couldn't imagine not purchasing that kind of insurance.
    Atwater Mike likes this.
  28. sunbeam
    sunbeam
    I told you to get rid of that Chinese torque wrench.
  29. gimpyshotrods
    gimpyshotrods
    Positive Crankcase Ventilation.
