Technical 46 chevy truck windshield leaks
Discussion in 'The Hokey Ass Message Board' started by EvenX82, Apr 6, 2023.
  1. EvenX82
    EvenX82
    Hello everyone,
    I’m curious to know what others experiences are with the crank out windshield on a 41-46 chevy trucks and if they leak. I have a 46 chevy coe build in process now with a brand new windshield frame and brand new weatherstripping from Steele. The gl*** will also be new as well, but I haven’t had the gl*** cut and installed yet. I plan on leaving the crank out windshield functional, but I am concerned about leaks.
    also, if others have any tips on reducing the chances of it leaking, I’d appreciate the advice.
    thanks everyone
  2. rudestude
    rudestude
    I had a 46 2 1/2 ton Chev wrecker with a tilt out windshield, I liked it ...sure a little water would drip inside when driving in the rain but while parked it would depend on how hard it was raining.
    I found by putting a little Vaseline where the rubber makes contact helps seal it and let's you still use it....I had one that someone had sealed it closed with looked like 10 tubes of silicone sealer.
    All new parts ,if fitted properly, will obviously be better than old worn out parts but remember that design was done when vehicle speeds were alot lower and in them days they were work trucks and not used for pleasure driving so the concerns of a little drip was usually not a big deal.
    Also make sure the crank is working properly and adjusted so that it pulls the window up snug but not so much to cause it to distort and twist out of shape and also cause leakage.
    lothiandon1940 and VANDENPLAS like this.
  3. Budget36
    Budget36
    I’ll be darned. When I meet up with pops in the afterlife I’m chewing some ***. He had a 1.5 ton ‘46 he built a rollback on to haul his Dozer. Spent many a hot summer day riding in that truck and wanting more air breeze. The one he had the windshield wasn’t a cranker.
    lothiandon1940 and Bob Lowry like this.
  4. Joe H
    Joe H
    My '37 is similar to the later ones so this may work on yours. I use a second seal around the windshield to stop all leaks, it fits in the cab opening for the windshield. The windshield frame hits it. It looks like a seal that goes around a trunk opening, soft rubber type stuff, universal fitting. The outer seal fits as normal and seals the frame to the outer edge of the cab, my inner seal seals the frame to the cab. I will get a picture later today.
    lothiandon1940 likes this.
  5. cshades
    cshades
    from wi
    i have never been able to stop mine from leaking. contrary to the thought that new parts help, the windsheild gasket that they sell now is not the same as the original. i have not added a inside gasket in the cab opening which might be a good idea. i am building a 39 with a chopped top/windshield frame so i may look at adding a gasket.
  6. Bikelessbill
    Bikelessbill
    I'm building a '49 International truck and it has a separate gasket that goes on body around windshield opening to seal against windshield frame when cranked closed.
  7. MMM1693
    MMM1693
    Had 48 aero sedan and the windshield leak was standard equipment
    Tow Truck Tom and lothiandon1940 like this.
  8. EvenX82
    EvenX82
    Thanks for the tips! I never thought of a seal against the cab that the frame would close against. Good idea! I’ll have to look into that! The Vaseline trick is also a good idea.
    I rebuilt my windshield regulator to work correctly and now works like new but nothing has been adjusted since I’m missing the gl***. I realize a lil leak back in the day wouldn’t have been a big deal since these were work trucks… but just wanted to get a general idea of how bad they would leak ( if at all ) to help me plan for placement of components under the dash.
    I’m ***uming the majority of leaks happened around the top of the frame and corners?
  9. Joe H
    Joe H
    In the rain, mine would leak in the two lower corners. '37s have hinges at the top, so the inner seal can only go around from hinge to hinge with a piece between the hinges. It really cut down the wind noise on mine. I had three different seals around the outside that all leaked, the forth was from Steele and has been working good for years now.
  10. lothiandon1940
    lothiandon1940
    Just remember, Vaseline is detrimental to rubber..Don't ask how I know!:eek:
    Tow Truck Tom likes this.
  11. rudestude
    rudestude
    Ok....I went back and did some online investigation and ....well forget about the Vaseline tip , yes it does help soften dried out rubber gaskets, but eventually breaks it down...but K-Y Jelly is OK.
    Oh ya I did read that it's NOT recommended for use as a *** lube either because it breaks down latex condoms and *** toys.
    Just saying....
  12. 05snopro440
    05snopro440
    I think that's a feature of all crank-out windshields, they leak. My dad has a 41 international, after about 5 years of trying to seal leaks he removed the frame and sealed it. If you expect it to be permanently wind and water tight without maintenance, you'll be disappointed. If you don't mind a little maintenance and the odd drip, then the second seal seems like a good plan.
  13. lothiandon1940
    lothiandon1940
    ....Right on. T-Tops and crank out windshields. They leak.:mad:
    05snopro440 likes this.
  14. 05snopro440
    05snopro440
    Yep. I took out the crank feature of my 46 GMC for that reason.
