Hot Rods 46 ford build
Discussion in 'The Hokey Ass Message Board' started by 46 tudor, Jul 16, 2015.
  1. 46 tudor
    46 tudor
    I'm starting to piece a tudor together and trying to decide on what ****** to run behind the small block chevy. Looking at the different suppliers products I see nothing for overdrive ******s, everything recommends 350 turbo, powerglide, or stick. What does everybody do to run an overdrive? Is Ch***is Engineering's bolt on mustang ll crossmember the way to go for front suspension?
  2. It depends on what you intend to use the car for
    I run a 700r4 but I wanted the overdrive for long trips and highway driving
    If you are going to drive it local with only occasional highway trips - the turbo 350 is simple
  3. Nothing wrong with the original suspension on a '46. I am guessing that you don't have an axle and a spring right?
    Most of the fellas use a 700R behind a small block I prefer the 200R if an OD must be had. The T350 will work well enough unless you are building mega torque in which case the 400 is a better option if you are not going with an automatic. If you want to go with a stick the high rollers are using TKO transmissions and the rest of us just use what we have like we have been doing for 40 or 50 years. LOL
