Hi, i don't have the original rear crossmeber for my '46 and need the mesuremntto weld the frame togehter(someone drilled ALL the rivets out).or the width of a crossmember. Thanks Michael
If nobody replies by the time I get home from work- I will meaasure my 47 frame and tell you what it is. SHould be the same. Do you want it in inches or centimeters? Jay
I have a piece I cut off my 46 frame, leaning against my garage, I'll measure it when I get home, in about a half hour. inside the frame and outside.
Thanks!! Could you give me the outside rail measurement too?? Frame is hacked up "inside". Thanks again Michael
I have 44 1/2" outside to outside. The crossmember overlaps the framerail 1 5/8" on top from the center. Each framerail is about 2 1/8" wide at the crossmember. Jay
