Technical '46 Ford gas line size
Discussion in 'Traditional Hot Rods' started by 1oldhotrodder, Jun 12, 2017.
  1. 1oldhotrodder
    1oldhotrodder
    I have put a 351W in a '46 Ford. The original tank I'm using has a 1/4" gas line and of course the pickup in the tank is 1/4" also. Is that going to be sufficient for a stock 351W? I am not a fast driver. Any ideas if this will be a problem.
  2. 325w
    325w
    My 36 had 1/4 inch at the tank. I added 5/16 the rest of the way. No problems. 350 crate 4 bbl carb auto trans.
    olscrounger likes this.
  3. I did the same as 325w, 1/4 to 5/16 via a Holley electric(RED) pump to my SBC with 600 cfm Edelbrock, runs great! I have a Hurst front mount so I can't use a manual pump.
  4. hotrodyankee
    hotrodyankee
    Ran a 5/16" line for my 283,and carter elec. fuel pump. All is good!
  5. 1oldhotrodder
    1oldhotrodder
    Thanks to every one that replied.
  6. leadsled
    leadsled
    yep -5 all day long
  7. Schwanke Engines
    Schwanke Engines
    Get some Nice Weatherhead 3/8" Pushlock line run it front to rear and use some good -6 AN either Weatherhead or Aeroquip pushlock fittings.
