46 ford pickup kingpins
Discussion in 'The Hokey Ass Message Board' started by the rookie, Jan 1, 2012.
  1. the rookie
    the rookie
    from spring
    im ordering a 3in drop axle for my 46 ford truck,from sid at dropped axles and i know its best to put new kingpins in it. how can i tell if i need a standard set or ones that are over sized? this will be my first kingpin set. i just want to make sure i order the right set the first time. is there a stock measurement or something i can do after i get my old spindles off my axle.
    Thanks
    The rookie
    oh any advice on getting the old king pins out and installing would help also.
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    I've never had to use oversize ones, just bought the standard set and had the bushings honed to the correct palm press fit and that was that. Don't see any reason why you would need oversized ones unless the bores in the axle are worn badly, and Sid would have known that, I'm sure. To be honest, I didn't even know they made oversized ones.
    BTW, there are however two different LENGTHS of kingpins. A shorter one for round back spindles (37-41) and a longer one for the squareback spindles (42-48). Just order accordingly and you will be fine.
    To answer your question, both the squareback and roundback pins are .813 diameter.
    Don
  3. the rookie
    the rookie
    from spring
    thanks i just saw in joblot that they sell a standard size and a over sized .010+ i didnt know if that mean the pin was actually over sized or the bushing in the spindle was oversized.
    best bet for having them honed is a machine shop?
    thanks for the help
  4. Mr48chev
    If it were me and I had br***/bronze bushings I'd take them to a machine shop and have them honed. I don't know about the oversize but have seen some spindles where the bushings fit a bit loose due to previous wear.
  5. Don's Hot Rods
    Don's Hot Rods
    from florida
    I agree with Mr48, I just take them to the local machine shop and have them hone them. It takes a hone that indexes on both bushings to get a straight shot, and they only charge about $ 50 locally to install and hone them.
    Don
  6. 55 Mercury
    55 Mercury
    All my axles I send out are standard kingpin size. I offer the service of installing kingpins and reaming king pin bushings.
    www.droppedaxles.com
