'46 ford spring question
Discussion in 'The Hokey Ass Message Board' started by dirtracer, Apr 10, 2013.
  1. dirtracer
    dirtracer
    I have a 1946 ford truck, completely stock. Can I remove a leaf or two from the front and rear to improve the ride and lower it a bit. If so, which spring(s) do I remove?
  2. dirtracer
    dirtracer
  3. You can and it will,just not sure which ones to remove.
  4. Tim
    Tim
    from KCMO
    It's a parallel set up in those trucks correct? You can remove leafs, no two that sit together you want to go every other to do what your talking about but I'm not sure if you'd want to start at the long end or short end of the pack pulling leaves. Give it a minute and I'm sure some one will chime in
  5. I've heard guys removing up to 3 in a passenger car, so 3-4 in a truck would be fine. Also take the main leaf from the front and rear to a spring shop and have them reverse the eyes. That'll lower it another inch.
  6. dirtracer
    dirtracer
    Will this affect the steering linkage in any way?
  7. pasadenahotrod
    pasadenahotrod
    from Texas
    Keep mainleaf and number 2, remove 3 5 7 staring with the shortest one.
    You may have to do this several times to get what you want and get both sides even.
  8. dirtracer
    dirtracer
    Thanks for the info so far!
  9. fordor41
    fordor41
    I went from 11 leaves to 7 or 8 in front on my '41 Ford Fordor. also a reversed eye main leaf. I experimented for years and finally settled on removing every other leaf with stock shocks.
    Watch the steering geometry as you lower it. Try to keep the drag link parallel to the ground to lessen bump steer.
  10. dirtracer
    dirtracer
    Thanks, tomorrow I will get after it!
