46 ford
Discussion in 'The Hokey Ass Message Board' started by fatfender, Mar 5, 2004.
  1. fatfender
    fatfender
    i have a 46 ford flathead 8 thats setup i' m going to pull and rebuilt any good place's for motor parts ?
  2. MBL
    MBL
    My first stop would be Joblot Automotive in Queens Village NY...they have professional and knowledgable staff. Order their catalog online. Patricks is also good. Don't forget Speedway either.
    Tim
    MBL
  3. fatfender
    fatfender
    thanks, i was hoping to free it up but i'v tried everything i can think of and it's still stuck
  4. MBL
    MBL
    You know my engine was wanting to stick for a while. We even broke a wrench trying to get it to turn. We tapped for a while on the pistons and shot a bunch of PB blaster into the cyls. Now it spins freely. Now mine was a motor that appeared to be recently rebuilt....but it sat for a bit. I would keep tapping and get a big pipe wrench....put it on the area behind the hex bolt on the end(closer to the block) So acutally on the pulley portion. The teeth on the wrench will grab....Take the heads off and douse the valves and tap them too. Free up anything that could drag on the motor.
    Tim
    MBL
  5. fatfender
    fatfender
    i filled the cyl wih kroil and let set three weeks every day i put a breaker bar on the end of crank and try back it both ways then i got in sid eon lift and put a big pipe wrench on it and still wont go then i got mad and towed it down the road no go soo i'll pull it and see whats in there. i got it of egay it came form mexico been setting 15 years
