'46 GMC project by Imperial Kustom
Discussion in 'The Hokey Ass Message Board' started by Imperial Kustom, Jan 19, 2012.
  1. Imperial Kustom
    Imperial Kustom
    Well, it has been so long since I have done a thread on anything, I figured I'd show you guys the '46 GMC pickup that is going together for one of my customers.
    First off, I am horrible about taking pictures as I go along, and I appolegize in advance for not having the earlier stages of this build and then there is still a lot left out.
    So here we go.
    This is one of many projects brought to me in the last year that has spent time at "reputable" body shops and then finally came to me do be done right. It originally came in for final prep and a pain job, but when I started blocking on it, things got a little funky. There was so many flat spots and waves in the cab that it was obvious it had to come down to bare metal and be redone from square one.
    After stripping the cab, sure as ****, the work was as sub par as it gets. Because it is an almost 70 year old truck, it has obviously seen it's share of use and abuse. Under the primer and filler was the half *** pounded out remains of a caved in roof. The previous shop didn't even try to reshape the metal. Thankfully it wasn't all that fatigued and didn't take too long to have it bumped around, shrunk and smoothed to the correct shape. The firewall also took some reshaping and shrinking as it was all warped up from welding in a bunch of new metal and making modifications. The rest of the cab was dents and dings coverd with filler, but they smoothed right out with the appropriate hammer and dolly work. I also did a ton of other little **** that I won't bore you with.
    The firs pic is after getting the cave out of the top and then bumping, hammering and dollying for a while. and the second is after more m***aging. I didn't get any pics of what I started with or how the metal looked before primer. I also didn't get pics of any of the other work on the cab before primer. I get to absorbed in working and by the time I remember the camera, it's too late!!
      100.7 KB
      81.3 KB
      77.4 KB
      63.9 KB
      63.7 KB
      81.5 KB
      60.6 KB
  2. Imperial Kustom
    Imperial Kustom
    Next up is the bed, and I didn't take **** for pictures of this.....
    It is a stubby little guy at 42" long, and it actually looks pretty good. The stake pockets are still '46 pieces and only took minor m***aging to get them straightened out. Just some dents around the bottoms to about halfway up, but they fixed easily. The sides are 16 ga. CRS with a 60* brake over the tops, which is then welded to .065" wall DOM for the rolled edges. The cross sills are 2X3" rectangle with some nice little frame mounts and the tailgate is the narrowed stocker. Nothing fancy at all, but it does the trick and looks good.
      67 KB
      66.7 KB
      66 KB
      71.1 KB
  3. Imperial Kustom
    Imperial Kustom
    This is where I am now. Getting the bodywork finished on this nose. The grille bars are repop '39 Chevy pieces, the top is '46 GMC hood pieces, and the rest is 18ga. CRS. There's a top and bottom deflector to guide air into the radiator and the headlights mount to the sides. The hood is only there for looks and covers just the upper air deflector but it still opens in the original clamshell fashion just for kicks. The latch is made of stainless and actuates by a pull handle under the chin pan. all the linkage hides behind the center grille bar.
      83.9 KB
      94.6 KB
      50.2 KB
      81.5 KB
      67.5 KB
      68.4 KB
      70.4 KB
  4. Imperial Kustom
    Imperial Kustom
    That's it for now but I will try my best to keep updated.
    Oh yeah, the truck is fenderless on an underslung frame but not horrendously low. There's a Isky solid cammed, 11:1 tri-carbed 348 and 4-speed for motivation and the paint is going to be Chromapremier in a basic green on the body with the interior, wheels, grille and beltline being a minty green. The ch***is is dark gray hammertone powdercoat. Rubber consists of the new Coker bias look radial blackwalls.
  5. Imperial Kustom
    Imperial Kustom
    Nobody cares about this thing? huh.
  6. resqd37Zep
    resqd37Zep
    from Nor Cal
    I care. Looks like you're off to a good start. It should get up and go with that 348 in there. Keep the updates coming.
  7. I'll watch, I love trucks !
  8. JJTF
    JJTF
    subscribed!
  9. bonez
    bonez
    from Slow lane
    Love the grille piece. I think is goin to be awesome.
  10. brett4christ
    brett4christ
    Sorry, IK! Don't know how I missed this yesterday! I'm a uber-nut for the 39-46 GM trucks!
    I'm watching!!!!
  11. Razorshotrods
    Razorshotrods
    from Phoenix
  12. rusty1
    rusty1
    ...I like it, keep us posted...
  13. 52Poncho
    52Poncho
  14. Imperial Kustom
    Imperial Kustom
    Managed to get somewhere on this thing. I am still learning to make picture taking habitual....
    But here's some interior pieces fresh outta paint. Have yet to cut and buff them, but they don't need much!! Too bad my cell phone pics ****. Oh well, here ya go...
  15. KWashburn
    KWashburn
    Remembering to do***ent is one of the harder parts about all of this.
    Looks good. Keep up the good work.
  16. Imperial Kustom
    Imperial Kustom
    It's a custom mixed DuPont SS urethane. The interior will be this color and the exterior is going A regular green SS urethane with the light green for accents and the wheels.. Both are from the ChromaPremier line and cost almost $1000 a gallon!!!!!
    Here's a picture of some ***hole....
  17. Imperial Kustom
    Imperial Kustom
    These pictures are of some off topic rides, but I just want to show some of the paint work that I do around here.
    First is a '71 Superbee in Plum Crazy Purple. DuPont ChromaBase and Transtar Qwik-Gloss clear. It works well and I love using it.
  18. Imperial Kustom
    Imperial Kustom
    Heres some before color sanding and buffing...
  19. draider
    draider
    from Texas
    That truck is gonna be sweet. Can't wait to see how the two greens go together.
  20. Imperial Kustom
    Imperial Kustom
    Next is a Kawasaki ZX14 that I did last week. I forget the paint manufacturer... something7000 deep black with once again, Transtar Qwick-Gloss. This stuff is impossible to sag or run and hardens very quick. But you better know how to spray for a mirror finish because it doesn't flow AT ALL!
    The firs picture is after color sand and buff. The rest are right after the last coat of clear was shot.
  21. Imperial Kustom
    Imperial Kustom
    Anyway, that's enough of the off topic stuff before I get burned. Just wanted to show off a bit I guess. After this GMC I have a few more on topic cars coming in, such as a '62 Impala SS, a '35 Dodge, and a '63 Chevy II SS a**** a plethora of others!!!
  22. Imperial Kustom
    Imperial Kustom
    It's all in the details. Even the small parts and inside the glove box get the gl***y smooth treatment!
  23. Imperial Kustom
    Imperial Kustom
    Here are some sneak peeks of the finished paint!!!! Remember, this is only single stage paint! It is DuPont ChromaPremier SS. Both colors. The owner of the truck is very anti-clearcoat.
    Sorry for the grainy cell phone pics. I took some better ones with my camera, but forgot it...
  24. 38Chevy454
    38Chevy454
    Nice work, the lighter green accent works good with the darker base color
  25. Imperial Kustom
    Imperial Kustom
    Couple-o-more...
  26. 383 240z
    383 240z
    Showoff. That being said I now need to go back to the shop and get back to work on my 41.
    Looks great. I'm painting mine in the Brewster Green and the belt line color will be the Sour Apple Green or black. Thats still up in the air.
    Please post pics of the ***embled cab if your doing that part of the job. Keith
  27. Imperial Kustom
    Imperial Kustom
    The customer is ***embling, but I WILL be taking pictures of it all together.
  28. Imperial Kustom
    Imperial Kustom
    FINALLY!!!! A couple pictures of the finished truck. Still need to find some interior shots though.
    That's the owner with my fiancee's daughter.
      527.5 KB
      520.4 KB
