47 ford coe (car hauler project)
Discussion in 'The Antiquated' started by corvettesander, Dec 25, 2012.
  1. farmer12
    farmer12
    Great looking exhaust ports!
  2. then i need some flame throwers :rolleyes: :)
    desided to go the difficult route :D and put them in the rear
    first i have polished the stacks and then weld them to the steel ring
    and drilled holes and bolted the stainless steel side panel and exhaust ports in place
  3. jfreakofkorn
    jfreakofkorn
    nice clean look to it ....
  4. Love the exhaust tubes!! Will they be functional?
    I am learning a lot from this build, the little details are awesome!!!
    Bill
  5. bengeltiger
    bengeltiger
    Tips are looking good. Still following along... Thanks for keeping us updated!
  6. yes they will, i still need to make the collector box to a single exhaust pipe
    but will first proceed with the side panels.
  7. some more progress
    the corvette in the back ground has the same color
    as the hauler will get (Atomic Orange) combined with metalic black and beige silver.
    here a sample of the atomic orange in evening sunlight
  8. seatex
    seatex
    DAMN, you've got some mad skills, man!
  9. bought a set of 40's ford car hubcaps to see if i could make them fit to
    the front wheels , did some measuring to see if the bolts would fit inside the hubcap and then cut the retainer ring off
    and test fitted them. also made a start on the other side's side panels.
  10. almost finished one side Just another one to go.....
    also reworked the dash so the ignition switch would fit nicely
  11. greaser
    greaser
    Outstanding job Sander! You'll need to hand out sungl***es wherever you go with this thing! Looking forward to see it all together.
  12. jfreakofkorn
    jfreakofkorn
  13. v8steel
    v8steel
    First - I've been following your project for a while now. I am really impressed and taking notes for when I finally get started on my project. Awesome work!!!
    Second - Just an idea... Are you using smooth or brushed stainless? I'm asking because I see the big arrows on the protective plastic, which usually indicate a "grain" orientation to the base material. I would hate to see all that work and material wasted when you finally remove the platic, only to see that something in the panel's finish doesn't line up correctly.
    Keep up the good work. Way Cool !!!!
  14. it has a smooth finish and will wet sand and polish it out to a nice gloss
    not high gloss mirror like, also abouth half of it will be painted.
  15. worked on the door skins today
    and made a brace for behind the largest piece
  16. Buddy Palumbo
    Buddy Palumbo
    Wow , that thing's looking slick ! Love the exhaust too .
  17. JRS T42
    JRS T42
    Do you mind showing a picture of how you set up what your screws that hold the side panels are being screwed into?
    Thank you.
    Enjoying all the work you have done!
  18. paco
    paco
    from Atlanta
    Nicely done straight forward metal work.
  19. these are held by rivet nuts http://www.youtube.com/watch?v=dkPhGIaPCVs
  20. Patrick46
    Patrick46
    those are cool. can't say I've seen those before.
  21. got all the gl*** made new
    and my dad is making progress on paint just one other color to go ! :)
  22. JOYFLEA
    JOYFLEA
    OH!:eek: I"M so jealous . The paint looks so good , clear coat on single stage?
  23. its base coat / clear coat (metalic colors)
  24. daddio211
    daddio211
    Wow man, slow down! :)
  25. kscarguy
    kscarguy
    No No, The sooner he finishes, the sooner he can fly to the US to finish mine
  26. beyond static
    beyond static
    from Louisiana
    Looks great! I can't believe how fast you're making progress. You'll be driving it in no time.
  27. yes yes i feel the pressure thats why i am in such a hurry :eek::)
  28. X Aero Painter
    X Aero Painter
    Corvette sander, Is that a tile paint booth?
  29. Yes
  30. put in the chrome grill inserts to see how it will look :)
    the color turned out pretty nice its black but has red and a little green metalic to it
