47 ford coe (car hauler project)
Discussion in 'The Antiquated' started by corvettesander, Dec 25, 2012.
  1. captmullette
    captmullette
    damn nice, looks like its gonna be heavy?
  2. got the wood in yesterday and have been working on it today
  3. Tnomoldw
    Tnomoldw
    hmm splinters....:eek:
  4. kscarguy
    kscarguy
    What,... where is the Brazillion Cherry and stainless steel bed strips? :rolleyes:
  5. no bed strip on this one ;) going to do something different :)
  6. also the 42-48 ford car dash arrived yesterday so i could not wait to put it in place :)
    stole the idea from doughboy, in therms of ''better well stolen than badly invented'' :D
    used the the top part of the old dash and did it a little different, i wanted to keep the ash trays
    some gap's to take care of
    and solved
    fitting the trim
    checking out the look of the gauges from cl***ic instruments
    speedo is in Kph
    just put the steering column on in the original mounting holes of the dash, but it just needs to go a little further into the dash
  7. kscarguy
    kscarguy
    Dash look outstanding. (Two thumbs up on that! ) However, I would ditch that aluminum column mount. It looks out of place with the very well executed dash and the period correct steering wheel.
    The brake pedal looks like it will be really comfortable. I like that setup better than my under floor master. Can you relocate the throttle mechanism in front of the firewall to clean that up?
    Sorry doughboy, but I like the ash trays...all this cool dash swapping, you guys have me wanting to put a 50 Ford dash in mine.
  8. i will paint both the column mounts and rework them to a more round shape.
    i have to look into the throttle pedal location and see whats possible
  9. farmer12
    farmer12
    What a great looking dash, just awesome! It fits right in with the whole character of the truck.
  10. woodbutcher
    woodbutcher
    :D Looking sweeter and sweeter all the time.
    Good luck.Have fun.Be safe.
    Leo
  11. kscarguy
    kscarguy
    My better half had a great idea...convert the ash trays to hidden vents...lift up the ash tray lid (hinged at the windshield) and reveal a/c vents.
  12. perkshotrods
    perkshotrods
    Subscribed, beautiful work.
  13. good idea but there will be no a/c :eek: most of the time its cold overhere
    so no need for a/c :)
  14. moved the steering column more under the dash and a little more to the left
  15. flynbrian48
    flynbrian48
    Are you sure that old truck is worth all the work? I mean, the upholstery on that seat is SHOT! Beautiful job on the dash. When an idea is as good as that, it's not stealing, it's inspiration.
    Brian
  16. castirondude
    castirondude
    Instead of a COE it is now a CIFOE, cab in front of engine :rolleyes:
    Sent from my Verizon 4G LTE smartphone
  17. kscarguy
    kscarguy
    OK, make them heater vents...!
  18. the seats will get new upholstery with a different patern that will match more with the rest of the truck .
    these seat come out of the donor truck and fit nicely
    my father will do the upholstery and also does the painting
    so we dont have the high labour cost on these.
    we can do most of the stuff our self, chrome is probably the only thing we need to send out :)
    tonight i have been working on the dash and
    cut some holes for the new gauges it still needs a little alignment
  19. castirondude
    castirondude
    No a/c also has the advantage of not having arguments over the a/c. I like it 80-90 degrees when i'm driving. When it's 105 out and 115 in the car then it's nice. But once you have ac then some folks insist it is set at 60. Too cold! I bring a jacket to work for the same reason. I only wear it inside the building, take it off when i go outside.
  20. working on some adaptors for the 5'' gauges
  21. kscarguy
    kscarguy
    Hey, you already have 0.6 kilometers on your truck, you must roll it around in that big old shop a lot. I bet you sit inside it and make engine noise too...vroom! :)
  22. xtremek
    xtremek
    I thought the first time you sit in any project vehicle with a steering wheel in your hand that was mandatory.:D
  23. no comment :p:cool:
  24. welded the adaptor rings in place and made the shifter into the dash
    i am using the shifter ***embly from the silverado steering column
    i will probably shorten the shifter handle a bit more and bend a small radius to it
  25. gatz
    gatz
    wow !...great job on the dash.
    I recall the neighbors 55 Plymouth had a small lever in almost that same location for the automatic transmission.
    Being a kid at the time, I couldn't understand how such a small lever could make the car shift gears.
  26. 41 Dave
    41 Dave
    Sander, Been meaning to throw in some of my comments. Just wanted to say that you are sure going to have one neat and low slung car hauler. Looking forward to more updates.
    Dave
  27. thanks again for the thumbs up :)
    i have finished up the other runningboard on the right side
    and have been playing with the steering shaft setup
  28. OahuEli
    OahuEli
    from Hawaii
    That CV type joint handles the top turn quite nicely.
  29. have been working on some floor pans
    and welded them in place also made a cover for the steering shaft
    will also make a piece to cover it up to the column bracket
  30. Tnomoldw
    Tnomoldw
