47 ford coe (car hauler project)
Discussion in 'The Antiquated' started by corvettesander, Dec 25, 2012.
  1. finished one side of the floor
  2. ChefMike
    ChefMike
    looks like a great project !!
  3. got the drivers side floor in too now
    next step will be finishing the steering shaft cover and making some seat frame's to lift the seats abouth 2 inch
  4. crazyeyes
    crazyeyes
    from AZ
    Damn!
    Sent from my DROID device using the TJJ mobile app
  5. flynbrian48
    flynbrian48
    I REALLY like the shifter! You're using the DBW throttle too? I was sort of happy my 6.0 was an '02 and still cable throttle.
    Brian
  6. Very cool project!! Beautiful craftsmanship.
    Bill
  7. olcarguy
    olcarguy
    Did you take any pics of how you finished the top of the shock mount. It looks real neat and professional. Rubber plugs to follow?
  8. mustangmike6996
    mustangmike6996
    from the D
    keep up the good work. looks awesome!
  9. no sorry i didnt took pic's but i first made a paper template
    and then made it of sheetmetal and rolled it to get the right curve
    it was not that a complicated piece to make :)
  10. Yes i am using the DBW throttle i only need to make the wiring a bit longer
  11. tonight i have been playing with the shifter and new (longer) push/pull cable
    and made a bracket under the dash
    and i have shortened the shifter handle and bend some curves to it
  12. Kustombuick
    Kustombuick
    what a great build, lots of thought and craftsmenship is going into this. A COE is one of my dream rides that I can build some day. Have you picked a color for it yet? Keep up the great work and keep the updates rolling in...Alan
  13. thanks :) not sure yet what color(s) it wil get
    any idea's ?
  14. olskoolrodder
    olskoolrodder
    fantastic workmanship!
  15. Fasttoys
    Fasttoys
    First rate craftsmanship to say the least, I am building a '47 also but it's a Chevy. Love the swifter, I did not realize the Silverado was a cable operated, you are using the same donor package as I hope to use. Mine will be pick-up style and my intent is to tow instead of tote them. Anyway,. many very good ideas here. One question: did you mock up the running boards with the radius to follow the bed? It's looking good the way it is, just curious what it would like turned the other way. Color is a tough choice to say the least, for me red and black make a good combo.[​IMG][​IMG]
  16. Kona Cruisers
    Kona Cruisers
    (NON HAMB LS POST... )
    On the DBW there is an extened policy (sort of a recall) on the TPS on the T/B. The correlation on the two sensors in the TPS goes all wackey and throws it into reduced power mode (happens more offten in COLD weather. I mean <15* F) but would leave you stranded... just a heads up.
    Also, What are you doing for the Tow/Haul mode activation?
  17. 1950kale
    1950kale
    thats a great looking truck! good luck with it.
  18. do you mean the winch activation ?
    i didnt check how it would look the turned the other way but would have been a good option too
  19. today i have made some seat mounts , this also to raise the seats a bit
    then welded them in place
    center console/seat frame narrowed
    also made the top piece on the steering shaft cover
  20. beyond static
    beyond static
    from Louisiana
    That came out great! It should be very comfortable to drive.
  21. yes they are ;) now i have to watch out you wont fall a sleep while driving :eek:
  22. Kona Cruisers
    Kona Cruisers
    No, Tow Haul mode is a function (actually a ****on on the column shifter) that change shift points, converter lock up, and locks out overdrive on the trans. keeps you from smoking a ******.
  23. Fasttoys
    Fasttoys
    Not to high-jack your great thread Corvette, but this may be of interest to you. For the tow/haul mode the later model vans had a push ****on on the dash for activation and a switch on the shift lever for up/down manual control if desired. The PCM should be able to retain these functions when it is re-flashed, just add a switch somewhere. As far as the cold weather issues I was not aware of these, but then again, in SC it's not a real concern, <15 degrees? ha, my fat *** aint leaving the house if it ever gets that cold.
    Fasttoys
  24. Fasttoys
    Fasttoys
    Corvette, are you thinking of any kind of a foot rest for the drivers side left or the p***engers side right? It may feel awkward with the foot at an angle due to the tilted floor. Column cover looks great.
    Fasttoys
  25. greaser
    greaser
    Rolling right along on this one. Suggest you consider adding a flat shelf for your left foot to rest comfortably beside the steering column.
    Looking GOOOD!
    Ha!, FASTOYS types faster
  26. ah i get it, yes the tow/haul mode ****on was on the old shifter handle
    i will add a ****on on the dash for that option.
    i was thinking abouth a rest pad for the left foot
    when i sat in it , i will see what i can fabricate for it :)
  27. kscarguy
    kscarguy
    I must admit that at first I did not like the looks of your column shafts, but now that it is covered I like it. IMO - I think a cover over the mounting brackets would complete the clean look. As for the floor, just grind the sole of your left shoe at an angle...ha!
  28. maybe i will cover the brackets too , i thought of it already
    or as i said i will round the sharp edges to get rid of the modern look
    so i have to make a matching set of coe shoe's :rolleyes:
  29. almost done on the dash added the clock in the middle of the dash
    and cleaned up a few not needed holes
  30. WillyNilly
    WillyNilly
    from NorCal
    New guy here with questions on COEs. It seems that a lot of the builds mount the engine in the middle of the frame, behind the cab, why? Corvette, yours came with a V8 already in the front location, why not leave the engine there? Is it a center of gravity issue? Or an access issue or is it for interior room? Just curious and it's a great build you have going. Everyone on the HAMB seem to have so much talent.
