47 ford coe (car hauler project)
Discussion in 'The Antiquated' started by corvettesander, Dec 25, 2012.
  1. its an interior room issue :)
  2. kscarguy
    kscarguy
    WillyNilly - When you sit in a stock 38-47 Ford COE (with the engine up front), you quickly find there is very limited leg room and even the stock steering column is offset by a few inches.
  3. WillyNilly
    WillyNilly
    from NorCal
    Thanks for the clarification. Would it be feasible to install a 6BT in it and narrow the dog house instead to get the room? I have a few ideas floating around in my head. One of my plans is to get an NPR and replace the cab with an older COE and run the diesel. It's also under the rear of the cab, but looks like it wouldn't be too difficult to do.
  4. 53 sparky
    53 sparky
    Willy- I've been considering the same NPR build concept. PM me if you ever get started down that road.
    Corvette, your build continues to impress me. Your attention to detail is inspiring. Keep up the good work!
  5. I know people have used the Isuzu NPRs, and I bought one for my project. I ended up not using it because the track width was too narrow for the Autocar and it had odd wheel sizes. (15.5s on 5 hole rims front, 17.5s on6 hole rears) I ended up with Dodge 1 ton dually axles under an International S series frame. (13 lettered **** spreader)
  6. have made a die for the tail lights i am going to use (65 impala)
    and this is a test stamp i did
    then made 3 in a row still need to staighten it here an there
  7. castirondude
    castirondude
    What does NPR stand for besides national public radio?
    Sent from my Verizon 4G LTE smartphone
  8. TrampHammer
    TrampHammer
    wow I'm digging it
  9. 65standard
    65standard
    Since you widened your front fenders, are there any issues with the doors hitting the fenders when opening? Just curious.
  10. uhh ?? :eek: actualy i didnt thought abouth that.
    just checked it out and i am lucky it doesnt hit, i should'nt went much wider
    then it would have been an issue
    and i have attached some more wood
  11. No Possible Repair
    Back to the build; I like the tail light thing you did, makes your truck individual. Anybody can dial 1-800-buy-****, not everyone can build a punch and die set.
  12. Ché
    Ché
    from PDX
    I think he is referring to one of these modern LCF commercial trucks:
    http://en.wikipedia.org/wiki/Isuzu_Elf
  13. made some more progress on the wood, and started making a border for around the edge. 2 long pieces made the corners wil be next
  14. Are you going to steam and bend the trim on the corners?
  15. no i will cut sections and connect them with dovetails
  16. well i have been playing with some wood agian and its getting along.
    made one corner , and got all the wood bolted down on the ramp
  17. farmer12
    farmer12
    Great woodwork skills! Looking even better every week!
  18. kscarguy
    kscarguy
    Are you going to have any provision for adjustable location wheel chock blocks?
  19. daveymac405
    daveymac405
    very neat, awesome attention to details.
  20. and i am not even a wood man ;) thanks !
    i am going to use 4 wheel straps, each strap will attach to 2 D-rings
    i figure that should be enough ?
    but plans can change along the way
  21. Great detail work!! Nice to see someone taking that much pride in their work!!!
    Bill
  22. OahuEli
    OahuEli
    from Hawaii
    Love that wood work!
  23. RMR&C
    RMR&C
    from NW Montana
    Very nice work. You are giving me a lot of ideas for my car hauler project.
  24. today was test fit day :)
    after this i have changed the rear wheel opening folowing the contour of the rear fender, and attached the fender to it.
  25. I just found this thread this morning. Read thru the whole thing. Very nice.
    Did you use self-tapping screws into the tubing to hold the bed wood?
    Thanks,
    Tony
  26. i've used Rivet nuts
  27. kscarguy
    kscarguy
    That looks good. How much did the rear suspension settle with the cars weight? Did you drive it or winch it up? (I see a battery in one photo)
  28. I've winched it up, I had lowered the. Rear suspension by 2.5 inch
    Before the ramp and wood was added so it already leaned over a little at the back. So i will restore its height close to what it was probably
  29. mcnally351
    mcnally351
    from boston
    Sick sick build you are talented bro
  30. second fiddle
    second fiddle
    In case it hasn't been mentioned....You do excellent work. I'm not sure if "craftsman" really does your skill justice!
