COE 47 ford coe hinge bead
Discussion in 'Off Topic Hot Rods & Customs' started by derrick1032, Mar 9, 2015.
  1. derrick1032
    derrick1032
    I had a few requests to show detail on how I made my door hinge bead. Rather than fill up my build thread I just made a new one.
    First off I use the purple 3M grinding disks. They are expensive but outlast anything out there and are made of plastic instead of the paper that shreds to easy. I cut down the backing pad on my 3" angle grinder. This allows me to grind the edge of the disc against a piece of s**** metal to keep a sharp grinding edge.
    Had to sacrifice a set of vice-grips to the greater good.
    First I trim with about 1/16 of excess to trim off later.
    I start with light pressure on the straight section to use as a guide for the corners
    I do a 45˚ corner p*** then tighten vice grips a little and make a second corner p***.
    Second p*** over the straight section
    tighten the vise grips a little more and make a third p*** except do two 30˚ corners Instead of one 45˚(starts to get the outside corner round)
    Third p*** on the straight section
    I used a #2 phillips bit as a punch to crisp up the corners ( a small punch would probably be better but I'm lazy and the bit was sitting right there)
    flip it over and do the same the the other side
    I use light pressure and keep my grinder moving in the same motion as if I was block sanding. It helps keep from digging in.
    trim the inside excess off
    I use the red fiber disk to finish. It gets rid of grinder marks and softens up any squarness. This was just a test piece, so a little extra attention to detail would make it real nice. I'd suggest make a couple trial pieces for practice first.
    daddio211 and vintage56 like this.
  2. 65standard
    65standard
    Thanks Derrick for sharing. Your metal shaping skills are amazing. I know your truck will turn great with the attention to the small details you're giving it. I'm going to give your technique a try on this as I'm making my own door skin.
  3. derrick1032
    derrick1032
    No problem. There's a bit of messing around to get it figured out. Once you get the hang of it, I did the last one in about 20min.
  4. daddio211
    daddio211
    You make it look so simple! Obviously there's years of skill and technique to get the final result, but you've given me the confidence to try something like this, thank you!
  5. vintage56
    vintage56
    Now I've pushed bead roller much higher on the "tools NEEDED" list!
    I'd heard of using skate wheels... How easy are they to chuck up in place of the steel die(s)? What brand of tool are you using there?
  6. derrick1032
    derrick1032
    Vintage56 - just a regular 8" pair of vise - grips to make the bead.
    The bead roller I got from KMS tools ( I think it's the same as Harbor Freight. They need bracing added as they flex too much without. A quick Google will give a bunch of examples.
    The skate wheels have a 7/8 hole for the bearing which is the same size as the bead roller dies. U just have to drill or die grind the little step that centre's the bearings. They are just friction fit and dont spin. I use spacers to stop from walking sideways. I made the tipping die out of a sheave from Princess Auto( there's hydraulic section)
