47 Ford Pickup Build
Discussion in 'The Hokey Ass Message Board' started by mtnxtreme, Apr 12, 2013.
  1. mtnxtreme
    mtnxtreme
    I picked up a 47 Ford 1-1/2 ton tow truck, pretty much rust free, I'm gonna put the cab on an S-10 ch***is, lowered with a big block Chevy, 5 speed,I was told the front fenders of the 1-1/2 ton have a larger opening thus may look funky on a pick-up, has anyone done this swap can give me some insight, if I have to I will just sell the fenders and get some gl*** pick up fenders if its that drastic, also found some steel bed suppliers, was wondering if anyone can give pros / cons on different companies, also EZ Swap bracketry for bolting down the body on the S-10 ch***is, anyone ever use it and has anyone done the 47 Ford S-10 ch***is swap can give me some insight. Sorry for all the hot air, thanks in advance.
  2. willymakeit
    willymakeit
    Do a search here on the S-10 swap. You proably wont get a lot of replies since this is a trad. site. Good luck.
  3. mtnxtreme
    mtnxtreme
    I actually found a huge thread on here abt. it like 20 pages, though its was shut down, but it was mostly abt. Chevy's, don't know how much different the Ford is, and couldn't fiond anything abt. the 1-1/2 tone fenders having a bigger opening than the pickup.
  4. HOTRODPRIMER
    HOTRODPRIMER
    S-10 is not the way to build a traditional hot rod,,it was shut down because it isn't. HRP
  5. mtnxtreme
    mtnxtreme
    OK well S-10 aside, the fender question is pretty traditional, and you guys would know better than anyone if they are same, different, look ****ty, someone must have tried to use the 1-1/2 ton fenders on a pickup. Maybe they are the same and the guy i got it from was wrong??
  6. 61unib100
    61unib100
    from Alpine, Ca
    I love those 42-47 Ford Trucks.... I am not 100% but I think 1/2 ton through 2 ton shared the same cab and fenders?? I have seen others and they look the same.
  7. oldrelics
    oldrelics
    from Calgary
    The larger fender openings will look like poop. Save your money.
  8. mtnxtreme
    mtnxtreme
    The guy I got it from claimed the front fenders were bigger openings fit the larger tires when turning and I should weld up some kinda lip to close them up more for pick up use, I hate to even do that, might be worth more to someone looking for something for a larger truck, and I would go gl*** if I had to, just trying to confirm.
  9. oldrelics
    oldrelics
    from Calgary
    If you going to go gl***, get 40-41 pickup fenders and a 35-40 car/pickup frame .
  10. 38Chevy454
    38Chevy454
    The front fender radius *IS* bigger on your truck. Cab is same as the 1/2 ton pickup, in fact all reg cabs are the same no matter what the weight rating of the truck.
    Any frame swap you need to be able to fabricate mounts.
  11. mtnxtreme
    mtnxtreme
    So can I still use my grill or I would have to use the 40 pointy wedge style grill,if so what else would be needed to switch to that grill style ??
  12. oldrelics
    oldrelics
    from Calgary
    You would have to use 40-41 parts.
  13. mtnxtreme
    mtnxtreme
    So a 40 grill, 40 fenders, grill leader piece, what abt my hood and bumper will they work?
  14. mtnxtreme
    mtnxtreme
  15. hotrod40coupe
    hotrod40coupe
    Bumper wiil, hood won't.
  16. mtnxtreme
    mtnxtreme
    Does anyone make a patch panel for that area immediately above the windshield, the top of the windshield on the p***enger side must have leaked and it rotted abt. 3-4" wide and it includes that little 3/8-12" roll in the metal, or I would just make it myself, or will I end up making it myself!?!?
  17. J'st Wandering
    J'st Wandering
    Buy a '40 or '41 if you want to go that way. Otherwise, all that you have is a cab that will work.
    The fender openings are too big. The value of the truck fenders are not that much because others are wanting to do the same thing that you want to do. So go ahead and cut them up. I do not know what it would take for them to look like pickup fenders.
    Search and you should be able to find pictures of pickups with truck fenders.
  18. J'st Wandering
    J'st Wandering
    The rot was probably caused by mouse nests. Take a look.
  19. mtnxtreme
    mtnxtreme
    Ya I've decided to just stick with all 47 stuff,if I'm forced to, I can always use gl*** fenders, I've been looking , but haven't found any [ickup fender except a few rotted and dented ones on e-bay.
  20. mtnxtreme
    mtnxtreme
    Kinda makes sense it had a one pice fibergl*** headliner and there was a mouse nest up on it, so it probably peed and ran down the gl*** and settled on the inner windshield header.
  21. Mooseandsqurl53
    Mooseandsqurl53
    from N.J.
    Do we get to see it?
  22. mtnxtreme
    mtnxtreme
    I gotta figue out how to upload from my I phone
  23. koolkemp
    koolkemp
    Heres some pics of my junk while we are waiting for his pics :D I scored this cab and ch***is last year from a buddy ....and a big pile of parts , no idea what Im gonna do with it yet or when ...
  24. Mooseandsqurl53
    Mooseandsqurl53
    from N.J.
    Kool, judging by what you've done with your other projects, I'm sure it'll turn out great.
