'47 Ford Pickup Mods
Discussion in 'The Hokey Ass Message Board' started by knuckle44, Aug 19, 2017.
  1. knuckle44
    knuckle44
    I have a 47 Ford pickup with a flathead V8. I would like to run a modern era rear end and wondered if anyone knows what rear end will bolt up with the least amount of modifications? Also, does anyone have a suggestion for a manual transmission? This truck will not be used as a racer nor has a heavy duty truck, just a cruise around vehicle. Ultimately, disk brakes up front, 12V, improved tranny & rear end but much of the rest of the truck nearly original. Thanks for your help.
  2. HOTRODPRIMER
    HOTRODPRIMER
    66-77 Ford bronco rear axle,you will still be able to use your original rims. HRP
    Early Ironman likes this.
  3. Early Ironman
    Early Ironman
    Come on, let's see your pickup![emoji3]
    This is after all, the land of show and tell!
    AVater likes this.
  4. '57-'72 Ford pickup rear will give you the right bolt pattern with a lot more options on gear ratios. If you want hanging pedals, a '52-'56 Ford car pedal assembly fits a '40-'47 Ford truck cab like it was custom made for it.
