47 pontiac rear end help
Discussion in 'The Hokey Ass Message Board' started by mrgasser396, Mar 10, 2012.
  1. mrgasser396
    mrgasser396
    from NEW YORK
    Hey guys does any one know if the rear end out of a 47 pontiac with a straight eight is the same as the 50s olds/pontiac rears ? I was told 37 thru 56 olds/pontiac rears are the same is this true ? it looks smaller than some of the olds/pontiac rears I have seen pictured here Thanks
  2. KoolKat-57
    KoolKat-57
    from Dublin, OH
    I believe 49-56 are the same, but not the same as 57-64 9.3" rears.
    48 and back might be the same to 56, I'm just not sure on those.
    Good Luck
    KK
  3. wastedchilhood
    wastedchilhood
    Pontiac 39 to 56 Olds 39 to 52. Pontiac built the rear ends for Olds. Gears from 3.07 to 4.56.
  4. 55chieftain
    55chieftain
    The only real break off is that 37-47 has ball bearing type pinion bearings, 47-56 has roller bearings...The Pontiac MPC show doesn't show the exact break off but list 47 with both, maybe early and late builds?
  5. mrgasser396
    mrgasser396
    from NEW YORK
    Thanks for the answers I have 2 more questiions Will the center section from the 57 to 64 olds / pontiac rears fit in this housing ?
    and if not can you get parts to rebuild the 47 pontiac rear I would like to use it because I like the way it looks and the price is right its free Thanks for your help
  6. mgtstumpy
    mgtstumpy
    I have a restorer friend with an early 1950ish Pontiac centre in his 46 Olds housing, direct bolt up. I doubt the larger 9" centre would fit in the early housing
