471 BLOWERS who's running one got one or have info on setting one up
Discussion in 'The Hokey Ass Message Board' started by continentaljohn, Sep 10, 2008.
  1. tmacracin
    tmacracin
  2. CheatersPete
    CheatersPete
    do you have a closer pics of the carbs set up?
  3. I wish I had that 4-deuce manifold - I like the off-set, but standard mounting setup! It reminds me of the 6-deuce 6-71 manifold that Savage is repopping.
  4. continentaljohn
    continentaljohn
    Great looking motors and love your set-up. I would like to put a eyeball on your setup and pick your brain a bit. Sorry that you and Mel couldn't come up for a shop tour if that's what you can call my junk. Yea I had planned on driving the 32 to the pile-up with the 471 but not sure if the Blower will be on her yet. Are you driving up with Mel and Aaron? I like to wake them up in the morning:Dnot under boost conditions and they like that. at 5 or 6 PSI of boost it should run fine you will need a good flowing exhaust and a cam change would be a good idea too mine is pretty detuned but very streetable and gets about 17 MPG I drive it all over the midwest with no problems so far
    On a side note I was gonna come up with Mel a couple weeks ago so I could meet you but our plans got changed and I couldnt make it I'll look for you at the HCP
    Mike[/quote]
    Hey Buddy I have Plenty of Chunks for ya:eek::D Did you get one yet?
    WOW Larry that is a nice set up please tell us more I love them 4x2's
    I too wish I had a 3x2 or 4x2 or even a picture of one to make a copy. I got a nice chunk of Alum to wittle out one or two but not sure on the design;) Any pics of one would be great!! I have it mocked up but no holes cut out yet.. What topper do you have?
  5. panic
    panic
  6. Garyr
    Garyr
    I've got 4-71s in stock-setup in sand blast they run $500 or set your's up for $250. I've got all the drive stuff too. Been doing blowers for 40 years. Gary Roushkolb Superchargers 316-393-1105 have hamb discount.
  7. 3wLarry
    3wLarry
    from Owasso, Ok
    All I know is that the pics were taken at this years Tyrod show...the coupe is a regular there.
    kidcampbell71 likes this.
  8. Sixcarb
    Sixcarb
    from North NJ
  9. CheatersPete
    CheatersPete
    NICE! where can I found an intake like this?
  10. Sixcarb
    Sixcarb
    from North NJ
    I see them pop up every couple years or so, it's a Cragar intake and drive. I got lucky when putting this car together and found the blower intake and complete drive that had been sitting for 35 years from a guy in the midwest.
  11. CheatersPete
    CheatersPete
    I'd'love to find one!
  12. ME TOO PETE !!
    Last one I saw was a Weiand on Egay and i missed out on it !! Havent seen one since.
    The 6x2 plate for a 4-71 is being repopped but not the 4x2.
    Ah well, keep looking ...
    Rat
  13. CheatersPete
    CheatersPete
    ok, then we propbably have to made it our own...
  14. fullhouse296
    fullhouse296
    from Australia
    For twin 2bbl adapter to 4/71 , see my website at wwwbrightworkmetalpolishing.com
  15. brigrat
    brigrat
    from Wa.St.
    Here's one mocked up in my '36 3/W in progress..................
  16. Here's one on a slant 6. The guy drove it to Turkey Run from over around Tampa and said it ran just fine.
  17. REJ
    REJ
    from FLA
    The one on the slant six belongs to me.
    I've been running it for the last 8 years with a 10% overdrive on the street. I can put 15 pounds of boost on it, but I will be doing some minor maintenance after that.
    Running one v-belt with two belt tensioners on it.
    Make sure that you install some sort of "sneeze" plate or you will end up with a nasty mess after the first backfire through the blower. Mine is real simple--I have a small aluminum plate with two holes drilled in it, have a hole smaller than it cut in the manifold, two bolts with valve springs holding the plate on. I have a gasket glued to the back of the plate, and if it backfires, the springs compress and take the bang out of the backfire. It will reseat and you can fire the motor and drive away.
    Once you figure out the timing, you should never have to worry about a backfire unless something freaky happens.
    About retarding the timing, one trick that I used was to hook the va***n to the distributor to the manifold so that when it starts making boost, the distributor no longer advances as far. I also run a water injection unit on mine and anything above 10 pounds of boost, I hit the switch for it to come on.
    It is not rocket science, but it takes a lot of fine tuning to get it to work like you want it to.
    Robert.
  18. Blown Mopar
    Blown Mopar
    from abc
    I'm running one on my 383" sbc. Any of the blower shops can provide a belt. I bought a 3" belt, they cut it in half to work on my 1.5" geared drive. Now I have a spare. I get 8lbs of boost. Don't try it without forged pistons. What Russco and Bored and Stroked said just about covers it.
  19. Tudor
    Tudor
    from GA
    Are you looking for one of these???????
  20. brandon
    brandon
    any of you guys running a boost reference fuel pump....? or is it necessary on a roots style setup ...?
  21. hiboy32
    hiboy32
    from Omaha, NE
    I hope to have one....someday!
  22. cali-chopper
    cali-chopper
    from belmont ca
  23. gimpyshotrods
    gimpyshotrods
    Have you got $2000 for the intake manifold?
  24. choppedtudor
    choppedtudor
    Just to keep this thread alive, I'll leave this for your comments.... gauges.JPG
    brigrat likes this.
