472 cad.
Discussion in 'The Hokey Ass Message Board' started by Hrodblack, Feb 22, 2007.
  1. Hrodblack
    Hrodblack
    Is there any manual transmissions that will bolt to a 472 cad motor?
  2. squirrel
    sure, most GM manuals from the mid 50s to the 80s or so. Just get a 65-up non-Chevy bellhousing.
    The tricky part is the flywheel.
  3. Rich Rogers
    Rich Rogers
    BOP bellhousing bolts to it. The flywheels are pricey and ya wanna make real sure the rest of the driveline is strong enough to hold it.They make more torque than a BBC motor. Puttin one in my 55 when I can gather the parts .Good luck
  4. Hrodblack
    Hrodblack
    thanks for the help guys i will do some more looking
  5. oldscule
    oldscule
    from il
    the crank most likely isn't drilled for a pilot bushing, so you would need that machined in there. Not that big of a deal, if he motor is apart.
  6. mad-cad
    mad-cad
    I have ran a Chevy NV 4500 5 speed manual behind a big block caddy in a 94 1 ton 4X4 truck... it would spin all four tires when the clutch was side stepped.I can email pics of the adapter ,the special flywheel and the crankshaft to input shaft bearing(which doesnt require any special machining ):D
    Mike who owns Schraders speed and style put a T56 6 speed behind a big block caddy ,Basically whatever GM ****** you want behind the motor you can have.
    I forgot to add that I have hanging on the wall in my shop a factory produced BOP bellhousing that has p***enger side starter and GM ****** bolt pattern.
    Tim
