48-52 Steering box, wheel and adapter question
Discussion in 'The Hokey Ass Message Board' started by Flathead Youngin', Jun 5, 2006.
  1. Flathead Youngin'
    Flathead Youngin'
    I thought while I was letting my welds cool for my model A to 48-52 truck box conversion, I'd ask a couple of quetions.
    I really want to use my 40 deluxe whee. I'm a little thick throught the belly :rolleyes: so it may be a little large in diameter.
    For the time being, I'm going to use the wheel in the picture below. I really like the diamter but I don't car for the style in the rod I'm building.
    1. Can I buy an adapter to put this wheel on a splined shaft? I have the adapter to put it on a keyed shaft like the older Fords had.
    2. What the heck is this wheel, anyway? It was on a column that I picked up off of a fella.......What year is it probably from?
    thanks!
  2. chopndrop
    chopndrop
  3. chrisntx
    chrisntx
    from Texas .
    Thats a standard replacement wheel that was common in 1973
  4. Flathead Youngin'
    Flathead Youngin'
    this was posted by "thirtytwo"
    "37 -48 p*** car internals will fit in the 48-51 f-1 box, steering shaft will be for a keyed wheel and the truck will have splines....thats the only differance, you will need the f-1 case and cover the rest you can steal from a p*** box.. hows that for cutting through the B.S.???"
    hmmmmis those shafts are the same length and mine has a good worm on the end, why couldn't I use one of my 37 and up shafts in my F1 box and guts????
    something to try tomorrow....any input?
  5. 29SX276
    29SX276
    I have a F-1 steering box in the Es***;I put the steering shaft from a '39 p***enger car in so I could use the '39 wheel.Fits perfectly.
  6. Flathead Youngin'
    Flathead Youngin'
    sounds good.....i'll tear one apart in a bit....thanks!!!
