48-53 flathead dizzy help
Discussion in 'The Hokey Ass Message Board' started by john mullen, Sep 4, 2011.
  1. john mullen
    john mullen
    I have installed edelbrock 3x2 carb setup w/ 94s on my 52 ford f1 with winfield su1-a cam and eddelbrock heads and merc crank. i don,t want to change out all thats needed to go to 12v and wan,t to convert the og ignition to something other than the vac advance that comes on the 8rt eng . it just dont work with this setup . I would like to convert the one I have to a standard va***e advance system as used in later model ford engines using manifold vac and centrifical advance . Has any one done this ? I want to keep the og dist because I moved the gen to the right side of the eng to make room for the 3x2 setup and the room under the bracket is limited .OK gear heads put your thinking caps on and help me out hear :confused::confused::confused:
  2. thunderbirdesq
    thunderbirdesq
    You're gonna have a REAL tough time converting that dist, no room for centrifugal weights in there. Guys have been turning down stock chevy/mopar distributors to fit for ages. Or find a mallory and go full centrifugal. My flathead likes the old mallory quite well!
  3. 36tbird
    36tbird
    Wow, totally new thread! Has the flathead distributor ever been discussed before? I'm gonna follow this one close. I wish this site had a search function.:confused:
  4. tommy
    tommy
    I like the OLD MALLORY idea. I got beginners luck and converted this old Mallory to Chrysler electronic on my dual 97 flathead before I even knew of the multi-carb problem. All mechanical advance so it ran like a top.
  5. wbrw32
    wbrw32
    As long as youve been a member here and dont know about the Search Function?????Its clearly marked at top of the page on each page
  6. flatjack
    flatjack
    Does the word facetious ring a bell?
  7. 36tbird
    36tbird
    Is it facetious to be sarcastic?;)
  8. john mullen
    john mullen
    did that . did not find what I was looking for...... You guys board or what?
  9. makemc
    makemc
    try bubba's ignition shop..he converts a chevy dist. to
    work on the 8ba flathead..makes a big differance.
    his no. is 1-888-809-3835
  10. Sheep Dip
    Sheep Dip
    from Central Ca
    Mallory full mechanical with your choice of electronics, I prefer Pertronix's but everyone has their pro's, con's, love's and hate's. Just be sure and have a distributor shop dial it all in before installation.
  11. tubman
    tubman
    One word : Bubba
  12. john mullen
    john mullen
    thanks to all who helped .called bubba and ordered chevy conversion today
  13. GMC BUBBA
    GMC BUBBA
    Thanks for the order , you will love it !!!!!!!!
  14. Sarge vt
    Sarge vt
    from Bristol,Vt
    contact Speedway Motors and order their flathead dual point mallory distributor.I just put one in my 50 flathead with isky 400 jr cam,edmunds heads johnson adjustable tappets 2 deuce offenhauser manifold and the ignition is fantastic.The stock vac advance units are not up to par with what u have and the Mallory is centrifugal and works fine in mine.
  15. Shaggy
    Shaggy
    from Sultan, WA
    newer mallory doesnt have the quality of the old stuff, atleast figure on replacing the points with napa stuff on the next tuneup
