Technical 48 bones w/ 8ba
Discussion in 'Traditional Hot Rods' started by nosdan, Nov 8, 2013.
  1. nosdan
    nosdan
    Will a pair of 1948 ford rear bones handle the torque of a stock 52 flatty (open driveshaft)? Or will I need additional reinforcement on the bones?
    Project is a 1930 Coupe.
  2. alchemy
    alchemy
    If you are splitting them to the rails of the frame, a stock Model A four-banger would break them. It's actually the motion of the split bones twisting as you go over bumps that cracks them.
    If you are using a flathead, why not use a torquetube too?
  3. woodypecker
    woodypecker
    Add reinforcement.
  4. 19Fordy
    19Fordy
    I think you need a torque arm. Check out hotrodworks.com and also do a HAMB search as there is lots of info. on this topic.
  5. Kiwi 4d
    Kiwi 4d
    You are wondering now , so unless you add a torque arm you will always be wondering if they will break. Add a torque arm for insurance .
  6. Put the front of the bones as close together as possible, not out to the rails (if possible) and yes put a torque arm in there. Bones are made to center the rear not handle torque. That said. Bones alone will work and handle the torque......... for a time. .....
  7. 19Fordy
    19Fordy
    Yes, but the time will be short. I am pretty sure someone posted (on HAMB) a cracked wishbone back by where it bolts to the rear axle/backing plate due to lack of a torque arm.
  8. OzyRodder
    OzyRodder
    I cracked mine several times, even with a torque arm. Had them triangulated properly just kept cracking them. As it is my daily i welded fish plates over the forgings and a strengthening rod along the top to the point where the tube welds in.
    Also welded a fish plate along top of the arc to tie the forging to the tube better.
    It was a trial and error thing and as they cracked I added more reinforcement. Have held up fine now for 6 months and about 3000 miles.
    If I had my time again( and I may do it next time they break) is build rolling bones style ladder bars.
  9. OzyRodder
    OzyRodder
  10. F-6Garagerat
    F-6Garagerat
    Check my build thread post 91 I think.
  11. aldixie
    aldixie
    It's says in your build that you were going to some how tie the arms together behind the Uniball mount, any pictures of what you did?
    Thanks,
    Alex
  12. F-6Garagerat
    F-6Garagerat
    Still need to do that. Just going to make a gusset out of 1/4" plate and connect them together so they move as a unit. I have driven it and seen it being driven from behind. Moves like it's supposed to.
  13. nosdan
    nosdan
    Thanks guys! I do have the front of the bones almost touching (under the trans)... but I'm going to add a torque arm and triangulate the bones...
