Technical 48 chevy 6 engine info
Discussion in 'The Hokey Ass Message Board' started by Steve Duleck, Mar 22, 2019.
  1. Steve Duleck
    Steve Duleck
    Hi,
    I need some info on this straight 6.
    Monday I'm goin to ***emble this motor at work. Its in the car.
    Don't know why the management didn't have the motor pulled to do it properly.
    No worries it is what it is.
    I need,
    wrist pin torque
    rod bolt torque
    ring orientation
    bearing clearance
    Oil pump specs
    There should be a book at the shop with this info, But seeing that I was told prior to leaving Friday I didn't have time to look. I want to be well armed and doing it by the book.
    Cheers
    Steve
  2. 302GMC
    302GMC
    from Idaho
    30 on the wrist pins - use a punch in the pin when tightening.
    40 on the rods, be sure of the amount of shims needed before final tightening.
    Stagger them ...
    .001 - .0015 on both rods & mains. As you know, shims determine clearance.
    Check for too much clearance in the gears & too much end play.
    Clean & align the squirters into the slurpers.
  3. Dan Timberlake
    Dan Timberlake
  4. Steve Duleck
    Steve Duleck
    Kool! Cheers for that.
    Steve
