48 chevy axle for suicide setup
Discussion in 'The Hokey Ass Message Board' started by 48reo, Sep 1, 2008.
  1. 48reo
    48reo
    I have a 48 chevy front axle and I want you to tell me why I cant use the existing leaf spring mounting points to mount some home made hairpins, and run the transverse leafs between the hairpins. If I make it all plenty strong I dont see why it wont work.
  2. onelowzuki
    onelowzuki
    It can be done, I have already done it myself, Just make sure you use "Quality" grade * or better hardware and also make sure the bolts are so tight fitting in the holes that they need tapped in with a hammer. There is over 26,000 miles on this setup with no signs of any failures. I am also doing this again to my reo project.
    I found this post when I went to update my wanted ad then I went looking at your project stuff. I will be calling you later about the windshield,
    Thanks
    Andy
