Projects 48 chevy suspension question
Discussion in 'Traditional Hot Rods' started by boothybunch, Jan 7, 2014.
  1. boothybunch
    boothybunch
    from UK
    Been reading on this forum for quite a while and finally decided to register and post up a question.
    I got myself a 48 chevy 6400 that i imported from the USA last year. It's having a major overhaul.
    I am putting modern suspension/axle under it etc and I decided on air suspension.
    I am planning on using the leaf spring that came with the new(used) rear axle as a suspension arm and then make a triangulated top link so it becomes sorta a 3 link setup
    I have the axle in place and the springs cut so i can see what's what and thought I would post up here to see what you guys think
    made some steel bushes/sleeves to put into the ch***is
    spring in place (will be made double shear)
    I am going to mount a pair of air bags I got from a semi truck trailer and mount them where the shocks brackets were.
    Top link is going to be constructed using a M20 Hi load heim joint and 2" tubing
    For some reason floating round in my head, I can't make my mind up if the cut down springs will be strong enough in their new role as suspension arms.
