48 flathead
Discussion in 'The Hokey Ass Message Board' started by 39fordor, Jun 10, 2009.
  1. 39fordor
    39fordor
    from nevada
    i am thinking about selling my 48 flathead with trans. But i am not sure what it is worth any ideas?
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Is it a 48 Car engine and trans, 59A and sideshift closed drive box
    OR a 48 Pickup engine and trans, 8BA and topshift open drive box?
    Rebuilt? One or both?
    Used and running or not?
    Stuck and noisy or not?
    So many questions, so little information.
  3. 39fordor
    39fordor
    from nevada
    i think the trans goes in the top was told it was rebuilt but not sure oil is clear and i can turn by hand easy missing the fuel pump.
  4. 39fordor
    39fordor
    from nevada
    and i do think the head says 8BA
  5. 28hiboy
    28hiboy
    from Milton, Fl
    I think all these "what's it worth?" post should be closed and deleted. It's a not for profit hobby-or should be. There--I said it!
  6. 39fordor
    39fordor
    from nevada
    not looking for profit it is in a 39 fordor that i am trying to hot rod but i dont want to give it away
  7. 33Tudor
    33Tudor
    I second the motion!
  8. HELLMET
    HELLMET
    then hook someone up that can use it. pay it forward.
  9. Jalopy Joker
    Jalopy Joker
    only worth what someone is willing to pay. do a search here and online for Ford Flathead motor For Sale (even if old ad, get an idea of value). online saw a Big flathead Lincoln w/trans for $300-another Ford for $7500
  10. Evilfordcoupe™
    Evilfordcoupe™
  11. A Chopped Coupe
    A Chopped Coupe
    There are too many variables when it comes to a motor that doesn't run but turns over.
    The last few flatheads I've bought were $150 and $100 complete.
    There is no way to find out if the block is cracked without tearing the who motor down and having it pressure tested and mag'd.....................unless it was verified that it had a 4" Merc crank that is the most I would pay, even if someone Said It Was Rebuilt, unless you have some proof.
    If the distributor comes out the front of the motor just above the balancer, it is a 59 series motor (48 and earlier), if the distributor comes out the drivers side and points up is is probably a 49 and newer........or 8BA type. If the motor has a built in bellhousing it is probably a 48 and earlier, if the bellhousing is bolted to the back of the block like a SBC/SBF then it is an 8BA or 49 and later motor.
    IMHO
